Dana 300 Questions ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-12-2007, 07:15 PM   #1 (permalink)
95 YJ
mx_scottj's Avatar
Member # 88021
Will a Dana 300 bolt up too a AX4 in a 95 yj. I though at one time somebody has done this but not for sure.
mx_scottj is offline   Reply With Quote
Old 03-13-2007, 09:16 AM   #2 (permalink)
butch6924's Avatar
Member # 29636
Send a message via Yahoo to butch6924
It depends on what it's out of...
80 and newer CJ's had a circular pattern D300 with the right bolt pattern, but, the output will be on the wrong side. You can flip the case with modified shift linkage or a modified housing via a flip kit, but you'll have to oblong a couple of holes as they won't match the stock pattern upside down exactly. Further, the short shaft D300 in the 80 & 81 models won't accept the electronic spedo assembly on the newer YJ's. You'll want one out of an 82-85 CJ7 for the YJ speedo to work.
Also, I don't know what an AX4 is. If you're talking about the AX5 5 speed tranny behind a 4cyl Jeep motor, the spline count on the trans output is different from the input on the D300 so it won't work in that regard.
butch6924 is offline   Reply With Quote
Old 03-13-2007, 10:23 AM   #3 (permalink)
Member # 82065
Send a message via AIM to xyjbeaker
perhaps an AW4?
xyjbeaker is offline   Reply With Quote
Old 03-13-2007, 12:17 PM   #4 (permalink)
butch6924's Avatar
Member # 29636
Originally Posted by xyjbeaker View Post
perhaps an AW4?
I thought that maybe too.
The same applies though as the AW4 and the AX5 have the same spline count on the output shaft.
Old 03-13-2007, 02:06 PM   #5 (permalink)
D53
D53's Avatar
Member # 83155
just in case you meant the AX-15 5 speed behind the I6 you will need to get this http://novakconversions.com/ but at the same time unless you are going to run a passenger side drop axle you will need to get a flip kit.
http://section8krawlers.com
D53 is offline   Reply With Quote
Old 03-13-2007, 07:11 PM   #6 (permalink)
95 YJ
mx_scottj's Avatar
Member # 88021
Thanks for your replys. I have a 300 out of a 84cj7. But no need to flip because I'm going full size chevy one ton so the drop will be right on!
Old 03-14-2007, 06:20 PM   #7 (permalink)
Member # 70172
Originally Posted by D53 View Post
...unless you are going to run a passenger side drop axle you will need to get a flip kit.
Flip kits are NOT required, save your money & get a proper adapter for a drivers side drop. Novak used to supply adapters for a Flipped D300 connection to an AX15, but I notice they no longer do that. The standard adapter (aka clocking ring) won't line up properly when you turn the case all the way around, but you could get a local machinist to make one for you.
Alfons is offline   Reply With Quote
