Member # 73191
Racing steering wheel in TJ?
Does anyone know what would be involved in installing a steering wheel like this in a 98 TJ? My old steering wheel on my beater is really worn and I would like to replace it with something like this. I don't need the stupid airbag so I thought I would get the huge wheel out of the way. If someone could point my in the right direction I would appreciate it.
Mr. DJ
Member # 85595
Is there away to keep the cruise control ?
MY BUILD ![]() http://pirate4x4.com/forum/showthread.php?t=748821 BUY MY JEEP!!! http://www.pirate4x4.com/forum/vehic...tml?highlight= |
Member # 74715
go over to the hardcore section and look at Mvdsluts build. He just changed his out for a grant w/ an adapter from summit
Don't talk to me about naval tradition. It's nothing but rum, sodomy and the lash. -Winston S Churchill |
Member # 73191
Thanks. As far as the cruise control is involved, I don't have it on my 98 but I'm sure with some ingenuity you could rewire the cruise control to some dash switches or something.
Member # 47727
I did it on my 97 TJ.
Undo the battery for a couple minutes to let the airbag deactivate. Undo bolts on backside of steering wheel and take off the cover then the airbag, disconnect plugs (I took out fuses too) Use a puller to take off the old stock wheel The nut that hold the steering wheel on I reused and ground to fit the ID of the new splined quick release coupler I got from summit (not necessary, can just weld coupler to stock column) weld splined coupler on to stock column grind flush and smooth and Bang, thats it! I used a grant steering wheel and had to widen the holes on the coupler just a little to make fit. Took about couple hours, but turned out nice. Makes getting in and out easier with my PRP's Justin
97 TJ HP 44 9" krawlers 88 XJ beater chopped on 35" tars 09 F250 FX4 6.4 PSD |
Member # 73191
Thanks grn97TJ, that is what I really wanted, a quick release wheel.
Snow you son of a bitch, how dare you steal my thread.......is this you? ![]() JKYeah, I took these pics at the 4x4 Expo in Houston. The jeep actually belongs to Bob Heath of St. Francisville, Louisiana I believe. He is a entry in the 2007 TTC. The jeep has also been featured in a few mags. It was rolling on some 47 inch LTBs and is a bad ass mutha. Here you go. Right click and save cause I will probably delete them soon. ![]() ![]() ![]() ![]() I was also cheesing over BTF's TJ. ![]() And their buggy on portals.
