AMC 360 Carb - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-26-2007, 10:21 AM   #1 (permalink)
Member # 362
AMC 360 Carb
Anyone have any suggestions as to what is a good off road 4 barrel carburetor for a AMC 360. Thanks
'75 CJ5 35's, waggy axels, 538's, NP435, AMC360 onboard air and welder
2004 Heritage Softail
SLADE is offline   Reply With Quote
Old 05-26-2007, 11:07 AM   #2 (permalink)
Member # 74881
I have a 360 also, installed an Edelbrock AVS 650 cfm with off road kit and after adjusting the floats it runs alright. Lets not kid ourselves its not fuel injection but it does alright for 90% of the time.
mika360 is offline   Reply With Quote
Old 05-26-2007, 11:45 AM   #3 (permalink)
loveshackle's Avatar
Member # 9925
X 3 (I've got 2 of the same). Gotta do the off-road kit & play with the floats. I'd say runs great 98% of the time. Doesn't like downhill with your ass threatening to go over ya.
"All great change in America begins at the dinner table" ~ Ronald Reagan
loveshackle is offline   Reply With Quote
Old 05-26-2007, 04:54 PM   #4 (permalink)
Member # 362
Thanks I think I'll go with an Edelbrock. What does the off road kit consist of?
Old 05-28-2007, 04:29 PM   #5 (permalink)
Member # 72257
I've been running a Quadrajet on my 401 and this thing is awesome on angles. Approach, departure, it doesnt matter...that, and it will damn near run sideways.
Keep in mind, a shitty Qjet is about as valuable as a doorstop, a good one however, that's been gone through thoroughly, is well worth it's weight.
I drive the fastest barbecue on 4 wheels...
CJim7 is offline   Reply With Quote
Old 05-28-2007, 04:40 PM   #6 (permalink)
bigbaggedbeast's Avatar
Member # 78847
just stay the hell away from the avenger offroad holley series ... no wait ive got like for of em 4 sale ...
rochesters seeemed good for all around but theirs no 4 barrels ... when u get on it u just use gas u don't really go any faster and the carters turn on better but need to be played with more often in my experance ... thank god for the day my tbi set up whent in ...
bigbaggedbeast is offline   Reply With Quote
Old 05-28-2007, 04:50 PM   #7 (permalink)
Moderator
apeters89's Avatar
Member # 7647
Motorcraft 2100 or 2150.
probably the best carburetor for offroading.
Check out our new Team Ape Eater Racing Like us on FaceBook
KF5EQF
Sniper Fab
4x4Oil SBwinVPS Custom Splice C2GFab
apeters89 is offline   Reply With Quote
Old 05-29-2007, 09:03 AM   #8 (permalink)
Member # 32187
Location: Selma, in the middle of the vineyards, Central California
Ditto!!!!
"[B]The Heep[/B]" 73 Commando, 258 I-6, T-18, Scout Dana 300 w/Tera 4:1 Kit, Twin-sticks, SOA, PS, Thru-dash Cage, Alcans, OBA, ARB's, HEI, Ft disc, Dents, Mud & Rust.
GoldToyBox is offline   Reply With Quote
Old 05-29-2007, 05:21 PM   #9 (permalink)
Member # 72257
Awesome carb for offroad, but is it enough for a 360 if it sees any time in the passing lane?
Old 05-29-2007, 05:27 PM   #10 (permalink)
Moderator
apeters89's Avatar
Member # 7647
I've got one on mine. It's no race car, but I was able to pass people whenever I needed to running 3.31 gears and 35's.
KF5EQF
Sniper Fab
Old 05-29-2007, 06:02 PM   #11 (permalink)
KiGrind's Avatar
Member # 66647
I don't run the interstate but I get enough power to wip in and out of traffic passing people on the street easy with my motorcraft. But I got a pretty much stock 304, got a 401cam in it thats supposed to help. I don't know if it does, i know its the best motor I've had so far compared to the stock 304 i had.
79 CJ-7
95 ZJ
KiGrind is offline   Reply With Quote
Old 05-30-2007, 10:06 AM   #12 (permalink)
Member # 32187
There are a handfull of MC 2100 & 2150 versions, obivously you don't want the 1.08 version for your 360.
You asked for an "off road" carb, so I'll stay with MC 2100 recommendation due to it's ease to work on & it's reliability.
Obivously a four barrel would have better "top end" preformance on the freeway.
Note: ford checks cfm at top of carb, while Weber & others at the throudle plates, so these numbers are suspect for comparisions.
2bbl Progressive 32/36 DGEV Weber = 300 CFM
2bbl Synchronous 38 DEGS Weber = 400 CFM
MC 2100 1.08 = 287
MC 2100 1.14 = 300
MC 2100 1.21 = 351
(Cubic In. Displacement/2)X(Maximum RPM/1728)= Maximum CFM
this assumes you want to run at max RPM to get that last MPH & HP, nothing you would want to do except on the track.
(360/2)X (5000/1728)=
(180) X (2.89) = 520
From another form:
Try it, you'll like it! I put a 350 CFM 2150 on the 360 in my old '69 F-100 and it runs great. I set it up at home (4,800 Ft.) and run it down to the Sacramento Valley and up to 9,000 feet without a sputter. I'd put a 2150 on my Jeepster but I can' find a 240 CFM
Here's a breakdown of the 2100/2150 flowrates . . .
0.98 - 190 CFM
1.01 - 240 CFM
1.02 - 245 CFM
1.08 - 290 CFM
1.14 - 300 CFM
1.21 - 350 CFM
1.23 - 355 CFM
1.33 - 425 CFM
Rockcrusher
Home of the Postal Jeepster
www.rockcrusher4x4.com
some more MC 2100 info:
MC2100s like 4 to 5 PSI, no more and no less.
The MC2100 is unique in that it will operate with the top removed.
The 1.14 could be found on the ford 351W and the 1.21 from the ford 351C all of the way up to the 390 CID V-8.
The Ford/Autolite 2100 was first introduced in 1957 and was installed on applications till 1974, In 1975 it was revised to become the 2150 and were phased out in the mid 80's.
The number on the side in the circle is the venturi size, Ford made 8 differing venturi sizes of the 2100/2150 depending upon the applications used. Since this was the ONLY FORD two barrel carburetor used from 1957-the early 70's Ford installed it on MANY differing applications. As you have noted even AMC bought this carb from ford for its applications. The venturi sizes ranged from .98, 1.01, 1.02, 1.08, 1.14, 1.21, 1.23, and the hard to find 1.33
The 2100 is very easy to tell apart from the 2150 as the 2150 is labeled Motorcraft on the carb top and has a choke vacuum break extending from the rear of the carburetor. You can also tell the later 2100's (70's versions) by the "raised" float bowl section and the choke unloader located just aft of the choke flap. (sometimes not used in the earlier 70's models).
OF course all 2100/2150's will have the part numbers stamped on the drivers side front foot which will tell the applications and year of manufacturer.
The earlier 2100's are probably more desirable as they’re are simpler carbs and were not tuned with economy in mind as are the later ones. Consequently the later ones tend to run a bit leaner and are often more temperamental, plus often have extra vacuum accessories.
The 2100/2150 carburetor has been reputed to be the BEST CARBURETOR series ever built. The 2100's are basically two barrel versions of the famed 4100 4 barrel carburetor and many parts are compatible.
Any other questions about 2100/2150's feel free to write me
Bill White
Good luck
White Automotive
Old 02-03-2008, 08:14 PM   #13 (permalink)
Member # 88551
I'm looking for a 1.21 2100 for my 401. Which vehicle should I reference at the parts store with hopes that the correct carb shows up?
cdazzle is offline   Reply With Quote
Old 02-03-2008, 08:35 PM   #14 (permalink)
smokd's Avatar
Member # 26329
Originally Posted by GoldToyBox View Post
Ditto!!!!
I also DITTO that. I ran the same motocraft on my 401 for 10 years in a 79 cj-7. Like others have mentioned, not a race car but the best alternative to EFI as far as I am concerned! Good luck!
If you have thin skin, thicken it. Sarcasm is the breakfast of champions........................BITCH!
"Any society that would give up a little liberty to gain a little security will deserve neither and lose both" - Benjamin Franklin
KJ6NQX
DDJC
smokd is offline   Reply With Quote
Old 02-04-2008, 08:42 AM   #15 (permalink)
Member # 88551
WHICH motorcraft? What venturi size?
Old 02-07-2008, 06:08 PM   #16 (permalink)
Member # 88551
Anybody have any info?
Should I ask this in hardcore?
Old 02-08-2008, 07:32 AM   #17 (permalink)
jackstand hero
bigjeep85's Avatar
Member # 65233
i say use a qjet. a well tuned qjet will out perform any other carb off road. they will work better than other carbs with all the offroad extras you can afford. i have one on my 360 and it works great.
87 FSJ, AMC 360, 727, STAK, ROCKWELLS, MVT'S
bigjeep85 is offline   Reply With Quote
