Member # 53171
LoMax, or TeraLow
What are your thought, opinions, or experience with either concerning the Dana 300 ? Not sure which way to go...
TIA
[I]82 CJ7 Granpa Pokey Jeep 01 Dodge Cummins, turned up 61 Porsche 356B 61 VW bug Ragtop 356B brakes Honda XLR 250 53 Nash Rambler 'Vert GM FI, and 700R4 and various others that come and go....[/I] |
Member # 56773
Teralow makes a 4:1 dana 300 kit. I'd go with the Lomax. I have the Teralow and from what I've seen the Lomax is beefier. The Teralow also has a 2 piece intermediate gear whereas the Lomax is 1 solid piece. I've heard of people breaking the Teralow gears but not the Lomax.
Member # 70509
I installed the TeraLow 3.15 kit in my Dana20. Easy install. But I gotta agree with the above. The LoMax kit does look much, much beefier.
"In the end...It's all Hack." |
Member # 32187
Location: Selma, in the middle of the vineyards, Central California
I've never seen a failure of a Tera-Low or LoMax Dana 300 kit personally.
Both suppose-it-ly have problems jumping out of gear with twin sticks. Mine does it at the damnest times. I have installed the "stronger springs" to help with this but don't see much difference. I don't plan to do anything until I have some cause to remove the T/C .... another fix involves some welding on the the shift rail. As mentioned above .... LoMax gears are supposed to be stronger, per their advertizements. I installed the Tera because Lomax didn't fit my application. I think there is some price differences too. The LoMax install instructions were better than Tera's when I did mine. (I used both and it went smooth). Both require some interior case grinding. Good luck! It's a great up grade for gearing down.
-------------------- "[B]The Heep[/B]" 73 Commando, 258 I-6, T-18, Scout Dana 300 w/Tera 4:1 Kit, Twin-sticks, SOA, PS, Thru-dash Cage, Alcans, OBA, ARB's, HEI, Ft disc, Dents, Mud & Rust. |
Member # 2037
I have the 4:1 LoMax gears in my D300 and love it! Beefy product with great Tech support. I'd also recommend you do the 32 spline output at the same time
Mark Langford KI6TMK '86 CJ7, ProRock60's, 4.88's/Detroits/35 Spline Alloys/CTM's, TBI 350, 700R4, 4:1 D300 w/Twin Stick, 17" x 8.5" Trail Ready HD Aluminum beadlocks, 37x13.5x17 Toyo MT's Dysfunctional Rockcrawlers (TDO) |
Member # 32187
Yep, good point, while it's apart is the time to do it! The rear output shaft takes most of the punishment. When you take a few apart, it's always the rear output shaft that shows the most wear.
