lifter question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-04-2007, 12:19 AM   #1 (permalink)
Member # 44063
Send a message via Yahoo to jeepdeepfreak
lifter question
89 xj 4.0
I have my valve cover off and was replacing the leaky gasket.While I was in there I was looking at the rocker arms and such and noticed that some of the push rods are harder to move up and down than others.I was thinking that fully primed good lifter would have enough pressure built up that you wouldn't be able to move the push rod down into the lifter??
Btw I did this with the pistons at tdc so both valves are closed...why would there be a difference in firmness bettween the two push rods?Do I have bad lifters that are bleeding off pressure or what?Am I being paranoid?Will they firm up when I start the motor?
aside from removing them to do an inspection how else can I test them??
Any input will be appreciated....
jeepdeepfreak is offline   Reply With Quote
Old 07-04-2007, 05:42 AM   #2 (permalink)
Member # 90393
i don't have the answer but if you don't have noisy lifters then probably no need to worry about it right? i had noisy lifters in my old 4.2 and changed out all the lifters, was quiet then.
rockrknockr is offline   Reply With Quote
Old 07-04-2007, 06:23 AM   #3 (permalink)
Little Jeep's Avatar
Member # 58117
2x.......... if no other issues, don't fix something that isn't broke
Little Jeep is offline   Reply With Quote
Old 07-04-2007, 12:50 PM   #4 (permalink)
Member # 44063
I do in fact have lifter noise....is it normal for hydro lifter to bleed off pressure overnight or after a few days?Would a leak down test confirm spongy collasped lifters?
Old 07-06-2007, 04:53 AM   #5 (permalink)
Member # 58117
I have never tested lifters. When they start to have issues, I just replace them (all of them).
Old 07-06-2007, 08:28 AM   #6 (permalink)
Member # 19031
Send a message via ICQ to gottagofast Send a message via AIM to gottagofast Send a message via Yahoo to gottagofast
no... lifters do not hold pressure... they can infact be compressed by hand... a collapsed lifter is a lifter that won't return when compressed.. if you have noise adjust the lash... if that doesn't fix it replace them.... get a chilton manual
Kevin
[URL="http://www.pirate4x4.com/forum/showthread.php?t=567624"]My build thread[/URL]
Killed the S-10 n2 jeeps now
gottagofast is offline   Reply With Quote
