No ac or heat on xj - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-13-2007, 10:49 PM   #1 (permalink)
Fabster
Randy's Avatar
Member # 3069
No ac or heat on xj
I have a 95 XJ thats the air, heat and fan are not working on. Anyone have this problem before and can tell be what to check?
Thanks
Randy
Thanks for the support
Currie Enterprises
PSC Steering
BFG Tires
Reid Racing
King Shocks
BTR wheels
LAT Racing Oils
Baja Designes
K&N
CBM Engines
Bulldog Winch
2013 KING
Bomber Fabrication http://www.facebook.com/pages/Bomber...4102610?v=wall
Randy is offline   Reply With Quote
Old 07-14-2007, 09:03 AM   #2 (permalink)
Member # 16217
Send a message via ICQ to JeremyH Send a message via AIM to JeremyH
Relay?
JeremyH is offline   Reply With Quote
Old 07-14-2007, 10:31 PM   #3 (permalink)
Fabster
Randy's Avatar
Member # 3069
do relays on jeeps go bad on a regular basis? Im a toyota guy and have never had a relay go bad.
Currie Enterprises
PSC Steering
BFG Tires
Reid Racing
King Shocks
BTR wheels
LAT Racing Oils
Baja Designes
K&N
CBM Engines
Bulldog Winch
2013 KING
Old 07-16-2007, 11:31 AM   #4 (permalink)
lazy bastard
ajcal225's Avatar
Member # 47629
Do they not work at all, or do they only blow out the defrost vents on the dash?
The latter is not uncommon and is confused for not working at all - while symptoms of drastically different issues.
ajcal225 is offline   Reply With Quote
Old 07-19-2007, 11:23 PM   #5 (permalink)
Fabster
Randy's Avatar
Member # 3069
nothing works, the fan doesnt run, no heat , nothing.
Currie Enterprises
PSC Steering
BFG Tires
Reid Racing
King Shocks
BTR wheels
LAT Racing Oils
Baja Designes
K&N
CBM Engines
Bulldog Winch
2013 KING
Old 07-20-2007, 05:13 PM   #6 (permalink)
Meow listen here
Rendered's Avatar
Member # 28140
Send a message via AIM to Rendered
When you say fan I'm assuming you mean the blower motor. I recently had a similar problem in my '95 XJ. What had happened was the connector on the back of the switch had melted, and was preventing contact between the switch and the wiring harness. If you pull the control panel out (pretty easy to do) and flip it around you will see what I'm talking about. What I did to fix it was remove the connector and crimp in new female insulated connectors and slid them onto the back of the switch. Everything appears to be working fine so far.
Rendered is offline   Reply With Quote
Old 07-24-2007, 10:59 PM   #7 (permalink)
Fabster
Randy's Avatar
Member # 3069
now thats some good tech right there
Currie Enterprises
PSC Steering
BFG Tires
Reid Racing
King Shocks
BTR wheels
LAT Racing Oils
Baja Designes
K&N
CBM Engines
Bulldog Winch
2013 KING
