Member # 86742
Dana 300 4:1 rear low pops out of gear
I have a flipped Dana 300 with Terra Low 4:1 gears and Down East Offroad flip twin stick kit in my YJ. My rear drive pops out of gear OFTEN when not under load. Has anyone else had this problem?
Any advise on how to fix would be great.Thanks, Chris Last edited by crandall; 07-20-2007 at 11:08 PM. |
Member # 66647
On a serious note, really just contact them and see what they do about the issue. They should know what you are talking about. If not, ask AA or Novak. Tell them you got there ring so they are extra nice to you.
![]() Novak always handles the questions great no matter what so I'd try them first. Should be the only email you'll have to make. |
Member # 69827
I put the Tera Lo 20 kit in my Dana 20. I left out the shift interlock for the rear so I could shift both front and rear independently. Not such a good idea. Mine pops out of Rear low or high. My solution is a bungee cord and a coat hanger. Works flawlessly.....
Some day I will correst the problem properly...
It's a Jeep Thing - No one understands! |
#11 (permalink) | |
Member # 66647
#12 (permalink) |
Member # 86742
I wanted to post the email response from Down East Offroad Inc. Hopefully this information can help the others in the field with the same problem:
Chris, I am familar with your complaint. What we have found is no matter whether the 300 is flipped or not, it is the twin sticks that cause this condition to surface. The springs work in tandam with a single stick design. Twin stick they are forced to handle there on pressure. The problem comes from the slide collars inside the case. When they get some wear on them, they have a tendacy to walk themselves down the shaft and work the shifter into neutral. Some people have fixed them by putting an even stronger spring to hold them in, but the true problem is the shift collars that the shift forks sit in. An Atlas with lots of use on it can do the same thing. Also make sure that the detent balls are fully sitting down inside the shift rail. I hope this helps, Let me know if i can help you anymore. Thanks Robert Bass Down East Offroad Inc. |
#15 (permalink) |
Member # 86742
Thats what I was wondering. I emailed Robert Bass with DEO asking him that very question. Maybe they sell them. I will post up as soon as I get a response. Unless anyone else knows....
#17 (permalink) |
Member # 86742
Here is a response I got on jeepforum regarding where to find stronger springs and detents:
call JB conversions and get the stronger detents and pills. $25 the other option is to remove your shift rails and gring the notches deeper. I don't have a 4 to 1 kit but jb said that if I find it popping out with the twin stick to get the detent kit and that should fix it. -I am gonna call them now |
#18 (permalink) | |
Member # 32187
Location: Selma, in the middle of the vineyards, Central California
Non flipped Dana 300 with Tera Low 4/1 with the JB spring kits & twin sticks Still pops out of gear when going down hill using the "gears to hold me back" (first gear low range). It can scare the pucky out of you! Someone posted up a mod to the shift rail .... never heard how well it worked.
-------------------- "[B]The Heep[/B]" 73 Commando, 258 I-6, T-18, Scout Dana 300 w/Tera 4:1 Kit, Twin-sticks, SOA, PS, Thru-dash Cage, Alcans, OBA, ARB's, HEI, Ft disc, Dents, Mud & Rust. Last edited by GoldToyBox; 07-26-2007 at 03:24 PM. Reason: added more info |
#19 (permalink) | |
Member # 86742
#20 (permalink) |
Member # 93767
From what I remember, putting the stock springs back in was not too easy, cant imagine those things compressing enough to allow room for two bearings in there... I think I would try taking a little of the slope off of the shift rod with a small grinder. just an idea
#21 (permalink) |
Member # 52005
When I first flipped mine I had springs in the shifters that were way too stiff made it tough to shift. I had 2 springs, 1 smaller one inside the slightly larger one. I pulled the smaller one out and the case shifted much better, but then the popping out of gear problem came about. I think I will try the bungy cord and coat hanger for a while until I need to drop the trans or case for any other reason. Thanks, Jake.
#22 (permalink) | |
Member # 86742
