Best Stock Drivers Side Drop T-case? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-22-2007, 02:03 PM   #1 (permalink)
Member # 84593
If you were to be able to put any stock junkyard Drivers Drop t-case into your vehicle, what would the choice be?
Personally I'd be thinking a NP231, but that's only because there isn't a whole lot of drivers drop t-cases out there. With the exception of maybe the ford NP205 but I dislike it do to size, weight, and lack of gearing.
HardcorewannabeXJ is offline   Reply With Quote
Old 08-22-2007, 04:41 PM   #2 (permalink)
Member # 68382
The 231C from a chevy s10 blazer, or the 241c from a late model (92-95ish) c/K truck. Both have 6 planetary gearsets on the input shaft, both have a wide chain (1.5"). Take the input gear from your 231 (21 or 23 spline) and you have an "HD" 231.
Tomb Raider is offline   Reply With Quote
Old 08-22-2007, 05:38 PM   #3 (permalink)
miguelitojeep's Avatar
Member # 73093
Im going to have to say a Rubicon 241OR rock track. I replaced my np231 with it not too long ago and couldnt be happier. I read somewhere the t-case was made to withstand the power from a cummins diesel. The only weak point is the chain, but its way stronger than a 231.
here is a small write up I did on it.
http://www.jeepforum.com/forum/showthread.php?t=399875
KOH 2013 Bom-Tec Racing #4476
miguelitojeep is offline   Reply With Quote
Old 08-22-2007, 06:02 PM   #4 (permalink)
Member # 68382
Did you find it in a junkyard?
Old 08-22-2007, 06:49 PM   #5 (permalink)
Member # 73093
LOL ok no but if your lucky you might. I got it off ebay. But I got a great deal and if you want a strong case with the 4:1 already in it than look for one of deez
Old 08-22-2007, 08:35 PM   #6 (permalink)
CJ4U2NV's Avatar
Member # 32034
best dside tcase is a clocked dana 300.
CJ4U2NV is offline   Reply With Quote
Old 08-22-2007, 09:59 PM   #7 (permalink)
Member # 73093
I also agree there are many aftermarket parts for these and can be re-built fairly cheap.
Old 08-22-2007, 10:50 PM   #8 (permalink)
Member # 80641
how about a flipped dana 300
[QUOTE=beater82;10779355]You should try patriotism. That stuff can fuck some shit up.[/QUOTE]
[QUOTE=DillWeed;9324924]Kid... you are looking for a dance club and you stumbled into an old school tavern full of mean drunks...Run for your life.[/QUOTE]
1990 yj, 44/60, d300, howell FI- sold
offroadjunkie is offline   Reply With Quote
Old 08-23-2007, 08:12 AM   #9 (permalink)
Ixer's Avatar
Member # 83544
Early bronco Dana 20...short, failry stout, can be twin sticked, lots of aftermarket support.
Ixer is offline   Reply With Quote
Old 08-23-2007, 08:19 AM   #10 (permalink)
ARB_jon's Avatar
Member # 87159
Send a message via Yahoo to ARB_jon
flipped, clocked
same thing
thats what im about to do use the 300 i got out of a 84 cj with the front half of my 231....
then i need a 44 up front
97TJ/4.0/ax15/231,300/44spool/8.8welded/4.10/36" iroks
www.lockitupoffroad.net/jong.html
ARB_jon is offline   Reply With Quote
Old 08-24-2007, 01:00 AM   #11 (permalink)
Member # 68171
Originally Posted by ARB_jon View Post
flipped, clocked
same thing
Your kidding, right?...
Knuckelhead
Knuckelhead is offline   Reply With Quote
Old 08-24-2007, 03:09 AM   #12 (permalink)
CJ4U2NV's Avatar
Member # 32034
this is why i love pirate....you can just feel the love.
Old 08-24-2007, 03:37 AM   #13 (permalink)
Hackfabricaton's Avatar
Member # 70509
NP205 with a NP203 doubler. Or if length was an issue just the NP205 with a 3:1 gearset. Both available in the boneyard. A NP205 is about as bulletproof as you are going to get in a stock Tcase. Just sucks gearing wise.
"In the end...It's all Hack."
Hackfabricaton is offline   Reply With Quote
Old 08-24-2007, 04:28 AM   #14 (permalink)
Member # 40312
02-05 NBS 1500 Rams use a driver drop 241HD with what might be a small count spline input. Chances are its a bolt in swap because theres a few guys who have bolted in Rubi 241s into full size Rams.
2003/Ram1350/5.7L/545RF/D60/Spartan/S10.5/Detroit/5.13
2006/F250/6.8L/ZFS6-650/D60/S10.5/LSD/4.10
CowboyKyle is offline   Reply With Quote
