Do 4:1 gears....
Do 4:1 gears for a Dana 300 t-case make that much of a difference? Ive heard the LoMax are better than TeraLow but are much more expensive. I already have the 258 together with the 6:1 T18. Would i get that much more out of it? I can find Teralow's for around $450. I still have the stock gears in mine.
1984 Cj-7,Currie 9" rear,Waggy dana 44,35's,4.56,fuel injected Inline 4.2,AGR steering, dana 300,t18 Last edited by PizzaFarno; 09-11-2007 at 04:27 PM. |
Member # 41802
I tried to wheel with just 4.88's in my tj on 33's, and it just wasn't enough. Since the 4-1 kit, I am very happy. I know I'm not close to your first gear ratio, but it still will be a huge improvement in crawl ratio for you.
Calling an illegal alien an 'undocumented immigrant' is like calling a drug dealer an 'unlicensed pharmacist' - |
Member # 17632
Does it do everything you want it to right now? If you find places where you say to yourself "Self, I'd like a lower gear in this situation", buy the low gears. If not, leave it alone.
Travis..
74 Ramcharger, 360, 4spd, 60/70 on 37s 91.5 Dodge 6BT 5 spd tow rig |
Member # 2037
I went with the LowMax 4:1 kit and love it! If you're a rock crawler, I'd bite the bullet and do it now
Mark Langford KI6TMK '86 CJ7, ProRock60's, 4.88's/Detroits/35 Spline Alloys/CTM's, TBI 350, 700R4, 4:1 D300 w/Twin Stick, 17" x 8.5" Trail Ready HD Aluminum beadlocks, 37x13.5x17 Toyo MT's Dysfunctional Rockcrawlers (TDO) |
your high range is 1:1 your low range is 2:1 ....... from 2:1 to 4:1 is the same amount od reduction as shifting from high to low...
ie if 1000 rpm is 5 mph in high then it is 2.5 in low and would be 1.25 mph with the 4:1 thus you have half the speed and twice the torque in the same gear at the same rpm from the 2:1 to the 4:1
Kevin [URL="http://www.pirate4x4.com/forum/showthread.php?t=567624"]My build thread[/URL] Killed the S-10 n2 jeeps now |
Phycho Guy
Member # 81388
The LoMax's are a One Pice construction versus the TerraLow's which are a 2 piece design that is pressed and welded. Personally I have seen 2 sets of TerraLow's fail. Sure they are warantied, but personally I wouldnt want to deal with it. When I get to the point of wanting the extra gear, its LoMax all the way for me.
Oh, and Yes, having the extra gearing is worth it
well I just read that the d300 has a 2.62:1 low.... if that's so then my earlier post is partly wrong... same gain over high but not as much gain over stock low ..... sorry
#12 (permalink) |
Member # 17632
You would go from about 70:1 to 109:1. My sami was 116:1 and it was stupid low, but it had zero torque so it was necessary. My Jeep is currently in the neighborhood of 40:1 and it isn't nearly as bad as it sounds. I think 70 would be good for me, but it depends how "hardcore" you are.
Travis..
#13 (permalink) |
Member # 82521
Actually I have been considering putting a Terra Low 4.1 in my CJ 5. With the 4.56s in the diffs, and an AMC V8 bolted to a wide ratio T18, the motor is turning 3000 rpms at 65 mph. You feel like you should shift up another gear long before you get to that speed but there isn’t one to shift to.
My thought is with that low an x-case, I could put taller gears in the diffs and have some better road manners, but still be “low enough” for the mud and the sand around here. |
#14 (permalink) |
Member # 56602
No don't do it! I'm tired of getting stuck behind all the guys that are too lazy to shift and creeping along along with some silly crawl gear.
80 CJ7 401/th400/300/hp60 Detroit frt&rr/38s |
#15 (permalink) |
Member # 53265
I love mine. I'm running the teralow 4to1 in my dana300. (I got a WICKED good price on the teralow stuff) sm465 and 4.10 gears in the axles, my low crawl is like 107 which is awesome.
#16 (permalink) |
well, i dont know if its worth the money because my crawl ratio is already pretty damn low with the low granny gear in the tranny(T18). Maybe ill go too low? Thanks for the comments and keep em coming please.
1984 Cj-7,Currie 9" rear,Waggy dana 44,35's,4.56,fuel injected Inline 4.2,AGR steering, dana 300,t18 |
#17 (permalink) |
AZUndertaker
Member # 89449
No such thing as too low!
In my book there is no such thing as too low of gearing, you can always use a higher gear in the transmission.
One exception to this rule is the lower your crawl ratio, the more parts you can break if you abuse the skinny pedal. I like the lower ratio so I can just idle over about anything, keeps from breaking stuff.
John Brock Rocking J Offroad Race Team/ Team Crossedup #4431 Thanks to our sponsors: Rocking J Offroad, LLC. Crossedup Customs ADS Racing Shocks Ruffstuff Specialties Applied Hydrographics Howe Preformance Steering JRat offroad/ Sixty9 Axle Reid Racing Letzroll Off Road Race Team Give these business your support so they can support us! |
#20 (permalink) |
Member # 70509
http://www.jbconversions.com/pages/p...max/index.html
Check out the beef on the LoMax gears...You decide if it's worth the money or not. You can get TeraLow stuff at a fraction of the cost of the LoMax, but....Depending on how you wheel, you might be throwing $$$ out the window... I installed the TeraLow 3:15 gears in my Dana20 Tcase, because other than the Bronco/Dana18 conversion there is no other mfg of lower gearing for the 20. There used to be someone, O'brien?, I can't recall that made better gears for the 20, but I don't know if he's still around or not. I have no 'real world' experience with them as yet. But the install was easy, although I had to grind a bit more than was expected on the inside of the case. The most difficult part was getting the end play set correctly on the output shafts.
"In the end...It's all Hack." |
#21 (permalink) |
To be honest if you feel your rig is already to low, then dont bother. It also depends on what type of wheeling you do. If your blasting sand and mud all the time, dont bother.. You need wheel spin, if your crawling rocks then I say do it but remember use second gear, no one likes to get behind people that have ultra super stupid low and use it on the trail because they dont know have to drive at a speed above 3 miles an hour on basiclly a dirt road.
I went from 40, to 60, to 80, to 112, to 145 and in some spots its ok, in others I would like lower. Right now I have great combination of gears at my disposal with a 7.05 first and 5.13s in the axles I am at 145 in first and 75 in second. For trails like the rubicon I am typically in second or third, For trails like the hammers second and sometimes first.
KI6PZZ, One of the wheelingpiazzas. Dysfunctional Rockcrawlers (TDO) |
#22 (permalink) |
Member # 51407
I have the terra 4:1 and its sweet. The LoMax stuff is stronger andi f you got the $$ go for it. If you are on a budget the Terra stuff is plenty strong for all around wheeling.
1986 CJ-7 with stuff |
#23 (permalink) |
Member # 63160
I have the LoMax but I have never heard anybody break the Tera gears. The LoMax was on sale when I bought it. I consider 4:1 mandatory for manual Jeeps with 4:1 1st gear in the tranny. But you don't have 5 gears so you need to do the math and compare the final ratios in every gear. After I looked at the calculations I found I paid for one extra gear below my old 1st gear in low range. 2nd thru 4th matched my old 1st thru 3rd pretty close.
