TJ high steer kit - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-13-2007, 06:49 PM   #1 (permalink)
97jeeptj's Avatar
Member # 93344
TJ high steer kit
I bent the tie-rod on the tj this weekend, along with my buddy. I'm guessing 2 bent on the same weekend of mild wheeling, we got a problem. I'm looking at the currie kit now on the net, but not sure exactly what all it entails. It appears to have heavy duty ends and rods, but not to raise the steering.
97jeeptj is offline   Reply With Quote
Old 09-13-2007, 06:55 PM   #2 (permalink)
Member # 43670
Send a message via AIM to milfordjeeper
check out this guys stuff . i have it put on mine. its out lasted a currie and if def alot stronger. ive hit mine more than a couple times and still perfectly straight
http://www.bandittoffroad.com/
**FOR SALE** .yota rear w/ full Detroit chrome moly shaft disc brakes 488s
"clayton 5.5, d60 rear 538 spool 35 spline shafts ,front hp d60 front 538s Detroit, 104" wb 39tsl's on some type of wheel lol ballistic/banditt hi steering MM 8000winch
milfordjeeper is offline   Reply With Quote
Old 09-13-2007, 10:32 PM   #3 (permalink)
Member # 98210
Send a message via AIM to JeeperSince3
I would look at phat jeeps steering linkage if you are still using your stock knuckles
http://www.phatjeeps.com/
also, if you want true high steer, Teraflex makes a kit that replaces the knuckles on a TJ D30 or D44
JeeperSince3 is offline   Reply With Quote
Old 09-14-2007, 05:18 AM   #4 (permalink)
Member # 68171
That (TF) setup only replaces the passenger side knuckle and screws up the ackerman angle...IMO
Knuckelhead
Knuckelhead is offline   Reply With Quote
