Member # 49315
HELP with steering issue... looking for possible diagnosis
weird thing happened last night with no foreseeable reason. I went to pull out of the driveway & only my left wheel turned. Maybe the right turned a little, but the front wheels were far from parallel. After straightening the wheels as best as possible & backing up a little to check things out, something popped & both wheels were responsive again. I was in a rush & didn't have time to examine anything... it worked, so I was off on my way to a meeting. The steering pulls a little to the right now, and the alignment is probably off, as both wheels are ever so slightly not parallel. The Jeep handled highway speed fine.
Do you guys have any idea of what I should check? Nothing is visibly loose and I can't figure out for the life of me what the "pop" was, except maybe threads sliding in/out somewhere? No offroad use directly preceded this, only a tire rotation 2 days before, and I can't see how that would be related. I'm running the Currie HD steering w/ 35s & a 4" AiROCK setup. We did lift the suspension up fully and lift the corners off the ground individually w/ a HiLift to work on some stuff - dunno if any stress could've been put on the steering during that, but I can't imagine that causing any problems. Could it be that I just need an alignment? I simply don't want this to happen again... Help. Thanks, Scott |
Member # 49315
They were tightened w/ an impact wrench, but I'll double-check. What difference would that make with steering?
Edit: checked. they're tight & all intact. Last edited by scott pruett; 09-20-2007 at 08:08 AM. |
Member # 17632
That Currie set-up has an aluminum tierod doesn't it? You might check the threads, maybe a TRE is pulling out like you said. I would check it immediately, you don't want to lose control at freeway speeds.
Travis..
74 Ramcharger, 360, 4spd, 60/70 on 37s 91.5 Dodge 6BT 5 spd tow rig |
Member # 99787
You have something seriously wrong. Do not drive the Jeep. Have a buddy turn the wheel back and forth while you look for loose or broken parts.
Appalachian Offroad Inc 410-848-2942 Westminster, Maryland Tube bending/notching, Rollcages, Differential Repair and Modification, Suspension, Chassis--> Turnkey, Custom Axles, Alignments Need pricing on any of the following product lines? Yukon, Rubicon Express, PRP Suspension Seats, Dana Spicer, Eaton, or Advanced Adapters..... Give us a call, pm us or stop by the shop for pricing or estimates. |
#7 (permalink) | |
Member # 49315
from another board (ROF):
#8 (permalink) | |
Member # 49315
don't worry, it won't be driven until I make sure all is well. |
F the Gub'ment!
Member # 70321
Location: Writing angry letters to anti-2A legislators--like you should be doing!
My Currie Currect-Lync (can that really be how that is spelled?) has the lock bolts really close to the sway bar attachments. I've been wondering if it will rub during flex and I figure I'll find out in the next two weeks in Moab. It's only been on about three weeks and I keep listening for noise made by the locking nuts that hold the TRE in adjustment rubbing against stuff in turns.
Nothing a grinder won't fix...
http://www.spiderwebshade.com/ |
F the Gub'ment!
Member # 70321
OK...a couple more things. "Currectlync" really is how it's spelled, just without the hyphen.
And, when I called Currie customer/technical service about some of my issues, I got good results. I was fighting a condition where I couldn't turn the wheels as far as I had been able to before the installation. I was asked if I had a dropped pitman arm. Of course: with my suspension setup it was necessary. Wrong! I was told that if I'd go back to a stock pitman arm then the Currectlync set up was designed to correct the geometry that was messed up by the lift. I was put in the position of having to find a stock :gasp: piece to go back onto my TJ. But it did fix the problem. Now I've got a dropped pitman arm to get rid of! The wheels turn just as far lock to lock as they did before the correction and now I've got two pieces of solid stock for a drag link and tie rod. Call Darryl in customer service at Currie and see if that might help.
#12 (permalink) |
F the Gub'ment!
Member # 70321
Hope it helps.
714.528.6957
