SYE on tj - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-03-2007, 11:53 AM   #1 (permalink)
Member # 98238
SYE on tj
hey guys. It's my fisrt post here but I'm reading for a while. I need informations about SYE. What will I need to perform this mod (my d35 is getting loose since I installed my 4'' lift)
SYE + cv driveshaft+ ??? (upper control arms or adjustable cam bolts, or something else ?)
I one to do it right it first time
thanks for your time and answers
Jo
jonathanfromquebec is offline   Reply With Quote
Old 10-03-2007, 12:04 PM   #2 (permalink)
Member # 11401
All you need is the sye kit and drive shaft. If you want you could rebuild your transfercase and install lower gears or 2lo kit.
Jtjwrangler is offline   Reply With Quote
Old 10-03-2007, 12:24 PM   #3 (permalink)
butch6924's Avatar
Member # 29636
Send a message via Yahoo to butch6924
Originally Posted by jonathanfromquebec View Post
(my d35 is getting loose since I installed my 4'' lift) ...
I don't see how this relates to needing an SYE?
You'll need to adjust your pinion angle after installing the SYE, adjustable uppers are the easiest way to accomplish that.
You'll also need the kit, the shaft, and a quality set of snap ring pliers. Honestly, try google. There's a handful of really detailed write ups out there.
http://links4jeeps.com/ has one.
butch6924 is offline   Reply With Quote
Old 10-03-2007, 06:21 PM   #4 (permalink)
Member # 80641
i didnt even read your post all i can say is dont expect people to just tell you answers. SEARCH YOUR FUCKING SELF!!!! Welcome to pirate
[QUOTE=beater82;10779355]You should try patriotism. That stuff can fuck some shit up.[/QUOTE]
[QUOTE=DillWeed;9324924]Kid... you are looking for a dance club and you stumbled into an old school tavern full of mean drunks...Run for your life.[/QUOTE]
1990 yj, 44/60, d300, howell FI- sold
offroadjunkie is offline   Reply With Quote
Old 10-03-2007, 09:27 PM   #5 (permalink)
Member # 98238
I've searched my fuckin' self and I got all mixed up by the whole bunch of different answers. this is why I asked. It's just to complete my search and confirm what I already know. So thanks for that amount of sympathy
and thanks for all the answers !!!
Jo
Old 10-04-2007, 09:05 AM   #6 (permalink)
Little Jeep's Avatar
Member # 58117
here is a Web site that walks you thru the SYE install almost step by step.
http://www.stu-offroad.com/engine/sye/sye-1.htm
BTW, this is still the non hardcore forum isn't it?
What happened to this forum being "Flame free"?
Little Jeep is offline   Reply With Quote
Old 10-04-2007, 09:58 PM   #7 (permalink)
Member # 38038
Yeah SYE is pretty easy to do.
I did a step by step as well. You can leave the T-case in the Jeep or remove it. I choose to remove it at the time, but its completely up to you.
http://www.links4jeeps.com/writeups/231sye/1.php
Links4Jeeps.com 1600+ Writeups, Clubs, Forums and Offroad Parks listings.
kizer is offline   Reply With Quote
Old 10-05-2007, 08:17 AM   #8 (permalink)
KVOM's Avatar
Member # 36715
This forum is supposed to be flame-free. Keep it that way.
If removing/disassembling your transfer case to swap the tailshaft seems liek more than you want to undertake, you can consider the Hack&Tap from Rubicon Express (it will be considerably cheaper as well). With a new CV driveshaft it's likely you will not need to modify the pinion angle, hence no need for adjustable UCAs.
97 TJ Buggy
2002 Ford F350 7.3PSD CC LB
KVOM is offline   Reply With Quote
Old 10-06-2007, 06:56 PM   #9 (permalink)
Member # 99982
its easy, just follow instructions with your kit. I thought it was a lot easier just pullin the case and puttin it on a bench then workin on it under the jeep, but thats just me.
90'YJ 258 1tons np435 d300
BUILTnotBOT is offline   Reply With Quote
Old 10-07-2007, 08:08 PM   #10 (permalink)
Member # 58117
I did the samething........ much easier to work on my workbench versus under my Jeep.
Old 10-10-2007, 05:35 PM   #11 (permalink)
Member # 66498
Send a message via MSN to patrickjeep
you dont need a sye for 4" lift but look for front housing angle.front cam bolt or ajust lower arm for prevent steering linkage
jeep tj 2003 dana 30 and ford 8.8 4.56 ratio 35"tires
patrickjeep is offline   Reply With Quote
Old 10-10-2007, 05:37 PM   #12 (permalink)
Member # 87845
half the time, when I search, I just find a bunch of assholes saying nothing but 'SEARCH YOUR FUCKING SELF'
y2knole is offline   Reply With Quote
Old 10-10-2007, 06:56 PM   #13 (permalink)
Member # 68171
Not true...
Knuckelhead
Knuckelhead is offline   Reply With Quote
Old 10-11-2007, 08:49 AM   #14 (permalink)
Member # 38038
After installing my SYE a few years back I can't imagine not installing one on any size lift beyond stock. 4-inch is a must. Why even bother trying to drop the case shim this and that. I would spend the money and do it completely right. Rear adjustable arms, CV shaft and a SYE.
Old 10-11-2007, 03:40 PM   #15 (permalink)
Member # 66498
just install lowering kit for t-c 2"
Old 10-11-2007, 03:47 PM   #16 (permalink)
Member # 24091
What's the point in LIFTING the Jeep, if all you're going to do is LOWER your skid plate?
OlBlueCJ7 is offline   Reply With Quote
Old 10-11-2007, 03:59 PM   #17 (permalink)
Member # 38038
Why not just do it right and install the SYE?
Then after that you can install a TummyTuck and get rid of the stock TC and gain a few extra inches under the Jeep?
Sure starting off low buck with a drop isn't a bad thing. I mean tons of people do it, but is it the "right" thing to do?
Old 10-11-2007, 05:39 PM   #18 (permalink)
Member # 68171
Clearance is a good thing (4" lift)...
Knuckelhead
Old 10-11-2007, 05:39 PM   #19 (permalink)
Member # 66498
it`s true buy a sye and cv drive if you are not cheap
Old 10-11-2007, 05:42 PM   #20 (permalink)
Member # 66498
it`s true is a cheap solution
Old 10-15-2007, 09:22 PM   #21 (permalink)
Member # 98238
ok, I have another question... as my budget is really tight these days. I'm asking you all about 1'' of bodylift and engine mount and a set of upperarm. it will corret the angle a bit like the sye... and I will save a few hundred $$$ I'm plannig for the SYE later... but for a few months... I can't afford it.
will it be effective as a ''cheap fix'' and I'll also have it later when I'll want to install a belly up.
so what do you think ?
jo
Old 10-15-2007, 09:41 PM   #22 (permalink)
schaan's Avatar
Member # 32012
Send a message via ICQ to schaan Send a message via AIM to schaan Send a message via MSN to schaan Send a message via Yahoo to schaan Send a message via Skype™ to schaan
just did mine today
teraflex extra short shaft kit.
wifes dd so no low gear set feasible.
schaan is offline   Reply With Quote
Old 10-15-2007, 09:42 PM   #23 (permalink)
schaan's Avatar
Member # 32012
Old 10-15-2007, 09:43 PM   #24 (permalink)
schaan's Avatar
Member # 32012
Old 10-15-2007, 09:47 PM   #25 (permalink)
schaan's Avatar
Member # 32012
jo
theres a hd sye kit for sale for 175.00 on my clubs site right now
http://www.kansaskrawlers.com/forum/...?TOPIC_ID=1446
better hurry
