Junkyard TJ front lockout swap options? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-17-2007, 06:29 PM   #1 (permalink)
CJHeap's Avatar
Member # 30944
Send a message via AIM to CJHeap
Question Junkyard TJ front lockout swap options?
I know about the warn kit but I want an economical swap option. What can I get the outer assemblies off of that will bolt up so I can have Warn Premium lockouts and 5 on 5.5 bolt patterns?
Thanks in advance
[B]Hammers Post 1461[/B]
[B]Tellico Post 160[/B]
[B][SIZE="4"][COLOR="Magenta"] Nikita Khrushchev said[/COLOR][/SIZE][/B][COLOR="DarkRed"][SIZE="4"]"We can't expect the American People to jump from Capitalism to Communism, but we can assist their elected leaders in giving them small doses of Socialism, until they awaken one day to find that they have Communism. "[/SIZE][/COLOR]
CJHeap is offline   Reply With Quote
Old 10-17-2007, 07:00 PM   #2 (permalink)
Member # 24709
Send a message via AIM to CartsXJ Send a message via Yahoo to CartsXJ
Basically the small bolt pattern hub is a ranger set-up and the larger a CJ. The biggest hurdle you will have to over come is the spindle that bolts up to the late model jeep knuckle. You maybe able to mod a CJ or ranger spindle to bolt-up, never really looked into it as I have the Milemarker set-up, which is the cheaper option, if you search around you can pick it up for $600.
"Being a man take years of fightin, screwin, drinkin, and whorin. Then more drinkin and then more whorin...if there's time" -Trippin the Rift
CartsXJ is offline   Reply With Quote
Old 10-17-2007, 08:41 PM   #3 (permalink)
CJHeap's Avatar
Member # 30944
I was wondering if I could change out knuckles and all?
Old 10-18-2007, 01:19 AM   #4 (permalink)
Member # 17632
I think your only option would be to swap "C"s from an early 30 so you can use dana 44 outers. There is a write-up in the tech archives about a hybrid 30 axle. It shows how to do it.
Travis..
74 Ramcharger, 360, 4spd, 60/70 on 37s
91.5 Dodge 6BT 5 spd tow rig
crashnzuk is offline   Reply With Quote
Old 10-18-2007, 11:20 AM   #5 (permalink)
Member # 24709
Yep, if you want to go that route, just do a search for Dana 30/44 hybrid, been done by a few and I believe Billavista has written an article about it.
Old 10-18-2007, 12:04 PM   #6 (permalink)
CJHeap's Avatar
Member # 30944
Thanks for the info.
Just trying to kill multiple birds with one stone.
1. lockout hubs
2. real bearings
3. 5 x 5.5 spacing so I can use my Champion beadlocks off my CJ
Old 10-19-2007, 06:28 AM   #7 (permalink)
CJHeap's Avatar
Member # 30944
It there a way to use the existing C's and mate knuckles out from a different application?
Old 10-21-2007, 06:51 AM   #8 (permalink)
CJHeap's Avatar
Member # 30944
I looked at the conversion and would rather not have to hack off the C's. Any other options?
Old 10-21-2007, 07:30 AM   #9 (permalink)
New Beginnings
jpfrk2001's Avatar
Member # 99513
I thought you can mate the knuckles from any d44 to the inner C's of a d30? take some measurments and just see. This I believe is true. The measurements are the same I believe. Just unbolt the knuckles from the inner C and put in knuckles from a d44. I could be wrong
jpfrk2001 is offline   Reply With Quote
Old 10-21-2007, 10:56 AM   #10 (permalink)
Member # 53301
That only applies to the CJ D30 axle, YJ,TJ,XJ,ZJ, etc all use a different axle and knuckle style then the CJ D30.
Stock '83 CJ-7
buddyholly010 is offline   Reply With Quote
