T150 pops out of gear? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-19-2008, 09:16 PM   #1 (permalink)
Member # 52745
My T150 pops out of 1st gear when I start to take off would this be syncronizer or maybe a bent shift fork? How would I be able to tell with out pulling the top off?
kodyowenby10 is offline   Reply With Quote Quick reply to this message
Old 01-20-2008, 06:30 AM   #2 (permalink)
nofender's Avatar
Member # 25958
Most likely syncros. It's very commpn with the T150. Have you ever had the cover off? If not, then I would vote syncros. A bent shift fork is possible, if the tranny was beat on.
nofender is offline   Reply With Quote Quick reply to this message
Old 01-20-2008, 11:02 AM   #3 (permalink)
Member # 40587
Id bet syncro's personally but if it was beat on it could be worse. Sadly either way the problem is inside the tranny. Id throw that piece of shit away and maybe look for a T-176 or a T-18. The T-18 being what i use. Throwing money at a T-150 is a waste more or less. Your stock bellhousing should work with the T-176 i believe, possible the T-18 as well.
The Black Sheep is offline   Reply With Quote Quick reply to this message
Old 01-21-2008, 08:32 PM   #4 (permalink)
Member # 52745
Would I have to modify my driveshafts to fit a 176 or a 18 also I have a SR4 I believe it is that the guy before me bought with a bunch of other random crap but Ive read they are pretty weak I am running a 304 with 38.5's
Old 01-22-2008, 04:36 AM   #5 (permalink)
Member # 40587
With 38's id run nothing less then the T-18. Its hard to tell if your driveshafts would work. Most of the "T" series trannies that came in jeeps were similar length. I would probably say plan on a driveshaft change and hope for the best if u did it.
