need engine wiring help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-29-2008, 06:02 AM   #1 (permalink)
Phillipj's Avatar
Member # 63981
I'm wanting to put a 95 throttle body 350 and 700r4 in my yj. Most the wiring in the yj has been removed. All i want is an ignition switch and start button. What i need help with is what wires do i need to hook up to make this work. Just a basic wiring diagram showing how the ecm works with the motor would be helpful.
Thanks
Phillipj is offline   Reply With Quote
Old 01-29-2008, 10:10 AM   #2 (permalink)
Member # 85688
Well start here:http://www.autozone.com/az/cds/en_us...rInfoPages.htm
next time give us more info, like WHAT YEAR YJ! ....you will probably need the GM eng computor! go to 'Painless Wiring' they got all your answers/needs ($$$$) Good luck, should be a nice set-up!
jerreyjeep is offline   Reply With Quote
Old 01-29-2008, 01:10 PM   #3 (permalink)
Phillipj's Avatar
Member # 63981
the year of the yj does not matter. I'm not useing any jeep yj wires. the question is how do i tie in an ignition switch and starter button. I've got the ecm and all the wires form the sensors to the ecm. I'm not useing a gm steering column.
thanks
