Yj Brakes Locked - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-08-2008, 06:48 PM   #1 (permalink)
Member # 94962
Question Yj Brakes Locked
What the hell would cause both front calipers to lock up?????????????? I Don't think they could both go bad at the same time !!could the proportion valve have something to do with it? Help please I have never even herd of this happening before
102joe is offline   Reply With Quote
Old 02-08-2008, 07:08 PM   #2 (permalink)
hoki06's Avatar
Member # 104183
Send a message via AIM to hoki06
i had both front calipers seize up within one weekend. i replaced both and haven't have a problem since. i figured since they were 17 years old that age may have been the issue, not sure though
1990 YJ - SOA & 35s
[url]www.novajeepers.com[/url]
hoki06 is offline   Reply With Quote
Old 02-08-2008, 07:26 PM   #3 (permalink)
Member # 7102
I've had one lock up and a week or so later the other one locked up. Made driving home interesting. Pounded them off the calipers as soon as I could so they wouldn't freeze in place and be a bigger PITA to remove.
Could be a lot of things. Warn caliper seals or crud in the lines. My calipers were originals from 1992 and it was early 2000's when they froze up. Luckily remans are dirt cheap. I think they were around $15 each. Haven't has a problem since.
Be careful taking the caliper bolts out they are a bit fragile and are a PITA to locate since they are metric graded bolts.
jeffy is offline   Reply With Quote
Old 02-08-2008, 07:35 PM   #4 (permalink)
Member # 19031
Send a message via ICQ to gottagofast Send a message via AIM to gottagofast Send a message via Yahoo to gottagofast
really easy to tell..... when they are locked... crack a bleeder... if they both instantly free up then it's not the calipers. if they don't, it is
Kevin
[URL="http://www.pirate4x4.com/forum/showthread.php?t=567624"]My build thread[/URL]
Killed the S-10 n2 jeeps now
gottagofast is offline   Reply With Quote
Old 02-09-2008, 08:36 AM   #5 (permalink)
Member # 94962
THANKS Why Didn't I think of that I check it out right now .
Old 02-09-2008, 10:19 AM   #6 (permalink)
Member # 94962
Wtf Now I Go To Check The Calipers And I Find That They Have Released On There Own Does Any One Know How The Proportion Valve Works ? Or Could The Master Cylinder Be Hanging Up ? Help!
Old 02-09-2008, 07:15 PM   #7 (permalink)
Member # 19031
they released slowly over time as they cooled.... go drive it and get em warm and stuck... THEN release a bleeder
Kevin
Old 03-09-2009, 10:51 AM   #8 (permalink)
Member # 24591
Any recent findings on this issue?? I had the same problem this morning, again.
I am starting to think I have a bad master cylinder. I know it shouldnt hold pressure, but when the calipers are locked and I bleed the line at the MC the calipers release. The master was NEW (not rebuilt) a month ago.
Still I am having a problem blaming the MC as it only pushes fluid. IIRC there arent any checks in a MC that would cause this problem is there??
I shot both rotors with my IR gun and the passenger side was 280* and the drivers side was 204* so I may still have problems in the passenger side??
I overhauled the pass side caliper just a couple days after the MC was replaced when the locked brake issue first happened.
Will one sticking caliper cause pressure to build so as to lock the other one?
I'm at a loss now!!
What say ye??
Rent this space!!
Binderman is offline   Reply With Quote
