Fly like an eagle...
Member # 52761
GL5 in the t-176
I have read everywhere that GL5 will eat brass bushings/synchros because of the high sulfur content. I mistakenly put in GL5 the other week when I put the rebuilt transmission in and it ran fine. I let it sit for a week and now it grinds when I have it in 4th gear pretty bad. It is obviously my mistake, but how fast does this stuff actually eat synchros?
TREC # 258 '81 AMC Eagle (Chocolate PopTart) Abrar: The Eagle makes a total of 400 hp (100 hp mechanical, 300 hp spiritual), so the parasitic loss is minimal. |
Member # 7102
Well, if you still have the bottles you'll want to check and see if the GL-5 has the MT-1 designation or not. GL-5/MT-1 is syncro friendly and was reformulated soon after the whole GL-5 issue came up.
Otherwise, it's hard to say how fast your syncro's will be damaged. You'll have to drain it and check for gold. |
Member # 46937
Yeah
If you trackdown the Amsoil white paper on gear oils, they actually run the copper corrosivity test on a bunch of GL5s. Most of them pass just fine. I believe the GL5 spec isn't required to pass that test. Doesn't mean it won't, doesn't mean the manufacturer didn't do it, just that it isn't in the spec.
________ Vaporizer Review Last edited by atblis; 08-12-2011 at 01:07 AM. |
Member # 46937
Yeah
I wouldn't rely on the MT-1 spec to tell you anything. In fact, it is intended for transmissions that are non synchronized. I can't find the tests it has to pass for the MT-1 spec so... A GL4 is what you want. ________ LIVE SEX Last edited by atblis; 08-12-2011 at 01:07 AM. |
#7 (permalink) | |
Member # 46937
Okay
According to Amsoil
________ BUY CHEAP VAPORIZER Last edited by atblis; 08-12-2011 at 01:07 AM. |
#8 (permalink) | |
Member # 7102
This is probably the one you're referring to. Mopar, Royal Purple and Lucas didn't pass but all of the others did. Page 17. |
Member # 90393
i don't see how the GL-5 could "eat" synchros in a week
![]() even the whole theory about it causing damage to synchros is hard for me to fathom but WTF do i know. i can say though that my AX15 works so much better with pennzoil synchromesh instead of the GL-5 75-90 shit. i might attribute to the pennzoil seeming a bit lighter weight than 75-90 even though i read it to be 80w. can't believe everything you read/hear
Member # 46937
Well
What brand of GL5 were you running?
It varies. I've heard rumours of failures within maybe 5-10 k miles. Not weeks though. It appears that most GL5s are fine for brass synchros. That's probably what makes this whole thing so confusing. ________ ROLL A JOINT Last edited by atblis; 08-12-2011 at 01:07 AM. |
