Member # 99475
MC 2100 help
I am working on swapping the carter BBD to the motorcraft 2100 on my '79 CJ7 with the 258. I have found most of the info I need on the internet, but I cannot find a picture of the bracket I will need to fabricate to change the throttle linkage from a rearward pull to a downward pull. Anyone have a picture or template that they will share?
'79 CJ7 Renegade '81 CJ7 Laredo |
Member # 7486
I cut part of the Carter bracket off and welded it to the MC bracket. It was a fairly small part, it didn't take much to get the right length to have it line up with the throttle cable.
I also had to make up a bracket to get the throttle return springs to work. I don't remember what I used there though, just a few scraps and part of an original bracket from the MC. No pictures to share of it though, but it was pretty simple. |
Member # 46937
Intake
Look on top of the intake manifold. There should be two threaded holes on top (there between the carburetor and the intake manifold).
Picture a bracket that bolts to those holes, goes over and provides a spot to attach the throttle cable. That's what you want. ![]() What cable are you using? I think you want a 304 cable. Maybe something off of a Furd. ________ BLCKPOIZEN Last edited by atblis; 08-12-2011 at 01:07 AM. |
