85 CJ-7 Lift questions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-13-2008, 11:33 AM   #1 (permalink)
Member # 108533
I am planning on putting a 4" suspension and some homemade shackles(around 1 1/4" lift). Am I going to need to get the driveshaft extended or is there any way around that. I'm a little short on cash.
85CJ is offline   Reply With Quote
Old 02-13-2008, 12:39 PM   #2 (permalink)
Member # 46937
I would
I would lose the shackle lift.
4", don't know about pinion angles, might be something else to consider.
________
Cams Sexy
atblis is online now   Reply With Quote
Old 02-16-2008, 09:58 PM   #3 (permalink)
Member # 14599
You'll probably need new driveshafts because they won't be long enough and the rear axle will need to be shimmed to point the pinion up. Forget about the shackle lift. Longer shackles in the front screw up your caster angle.
jeepnuts99 is offline   Reply With Quote
