upgrade questions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-22-2008, 09:19 PM   #1 (permalink)
Member # 102595
upgrade questions
i got an 85 cj7, my goal in the rig woulg be mild wheelin( mud, sand, gradual hill climbs, not to much rocks, nothing to intense)just a more reliable drivetrian. dont need a whole lot of flex i wanna stay with leafs and an anti wrap kind of setup. i dont wanna go full width or stretch. what axles are gonig to be more closer in length wise to the cj7 set up so that theres no out boarding.
DKWitaCJ7 is offline   Reply With Quote
Old 02-23-2008, 07:29 AM   #2 (permalink)
Member # 97644
it sounds like you should just keep the stock axles.maybe upgrade the axle shafts if you break them.what size tire do you plan to run?
t.j.,tons,116",full hydro,40"creepys....... short fingers
txdave is offline   Reply With Quote
Old 02-23-2008, 02:12 PM   #3 (permalink)
Member # 102595
i runnin 33s but if i go bigger 36s would be the biggest, i always hear stories of the axles being rubbish, but if u think that would be my best bet thanx for the info, i would appreciate more info and opinions from others thanx
Old 02-23-2008, 02:56 PM   #4 (permalink)
Member # 80155
what rear end is in it a amc20??? I hear those stand up pretty good with upgraded 1 piece axles
runemuck is offline   Reply With Quote
Old 02-23-2008, 09:55 PM   #5 (permalink)
Member # 102595
so thats 2x on jus up grading the inner shafts thanx for the in put.
Old 02-24-2008, 01:18 AM   #6 (permalink)
kingmick217's Avatar
Member # 44327
Send a message via MSN to kingmick217
x3
I run an '85 CJ-7 myself...
If You have the more Common set-up 4.2l/T-4/D300 drivetrain and don't get too happy with the stupid pedal, than upgraded axle shafts are all you should ever need in your stock axles with 35" tires. If you stay with 33" or less than I wouldn't do shit to your axles untill they actually broke (probably won't).
I run bone stock axles in my CJ-7 right now with factory 3.31 gears in them behind a 360/tf727/D300 set-up. Last summer (running 33x12.50R15) I accidently hit the shifter (don't ask) into reverse at 55mph and didn't break a damn thing, and i still run two-piece shafts with 179,000 miles on the odometer. If that doesn't put your mind at ease about the strength of these axles what will.
Don't go doing the Dana 60 thing just cause everyone else tells you that you have to. If you have the money go for it and never worry about you're axles again, but if you're like the rest of us wheel what you've got. if you stay below 33" tires I wouldn't even switch over to the one-piece shafts untell they break.
Oh you sir. You are definitely fired.
kingmick217 is offline   Reply With Quote
Old 02-24-2008, 12:31 PM   #7 (permalink)
Member # 102595
thats a good testiment to the 20, thanx for the encouragement. ill keep all these opinions in mind and see wat happens thanx guys
