2006 jeep unlimited light dont work - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-18-2008, 12:27 PM   #1 (permalink)
Member # 26490
I have a 2006 jeep unlimited rubicon. The head lights, dome lights, front hazard lights work.
The rear tail lights, blinkers,hazzard and reverse dont work. The dash lights dont work, the front parking lights dont work and the front blinkers dont work.
Checked fuses under dash and on firewall and all fuses are good.
Any suggestions would be appreciated
Thanks Scott
Scrambler Scott is offline   Reply With Quote
Old 03-18-2008, 12:45 PM   #2 (permalink)
BWB Jeep's Avatar
Member # 107947
Are your rear lights plugged in?
BWB Jeep is offline   Reply With Quote
Old 03-18-2008, 12:48 PM   #3 (permalink)
Member # 26490
yes
Old 03-18-2008, 12:55 PM   #4 (permalink)
Member # 47888
While you're waiting on someone who knows TJs to reply, it sounds like a plug came loose. Check any plug connections and wiggle them to see whether any of the lights go On/Off with the switch on. (I'm thinking under the dash, close to the fuse box)
Also, not sure what you mean when you say the front hazard lights work, but the front blinkers don't work.
Good luck.
WTF-J - WTF gives you freedom. Freedom brings opportunity. Opportunity makes your future.
THachiya is offline   Reply With Quote
Old 03-18-2008, 02:08 PM   #5 (permalink)
Member # 26490
the hazards work in the front but not in back. When i put the blinkers on they dont flash.
Im thinking it may be the switch on the column are no power to it.
Old 03-18-2008, 04:14 PM   #6 (permalink)
Member # 26490
Ttt
Old 03-18-2008, 05:25 PM   #7 (permalink)
Member # 108872
Send a message via AIM to MonsterSeven Send a message via Yahoo to MonsterSeven
could be a faulty blinker relay...try that.
*98 RHD TJ: swapped 4.0L/AX-15/Dana 300, 4.88, AEV 3", LP9"/S88, Grizzly/Detroit, OTK steering, 35" muds... 84:1.
*85 CJ-7: GM350/NV4500/D300, SOA on Wags, LP44/LP9", Aussies, 37" MT/Rs, Staun beadlocks, hi-steer, 110:1... in pieces.
MonsterSeven is offline   Reply With Quote
Old 03-19-2008, 04:25 AM   #8 (permalink)
Member # 26490
fixed. thanks for the help
Old 03-19-2008, 11:51 AM   #9 (permalink)
Member # 47888
Soooooooooooooo, what was the problem?
Old 03-19-2008, 12:58 PM   #10 (permalink)
Member # 26490
I bought this jeep rolled and put it back together. Went to big meat run and i never tested the lights. Somebody cut the wires under the inside opening of the door running
to the back tail lights. i put the wires together and they worked plus the dash lights are working also. The jeep only has 3500 miles on it.
