links and travel - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-25-2008, 03:24 PM   #1 (permalink)
Drive slideways
Member # 81214
links and travel
Making the move to coil overs. My 3/4 link exceeds what coils can do. Is there any real world benefit of 16" CO's over 14" CO's? I know 2" more travel.
But is the amount of work needed to make 16's fit worth 2" more travel? what are real world numbers for travel on a TJ? Either way it's going to have 3" up. I'd just end up with 11 or 13 down.
Originally Posted by petro812 View Post
He's got some of the basics down, but in the end that's just got to create a bigger clusterfuck in that chinese fire drill of a cognitive thought he brought to the dog and pony show of his new found awareness.
Never Monday is offline   Reply With Quote
Old 03-26-2008, 10:57 AM   #2 (permalink)
Drive slideways
Member # 81214
I'm guessing the size coil overs people are using is classified info?
Old 03-26-2008, 11:11 AM   #3 (permalink)
Member # 78458
by tilting or mounting the coilovers at a slight angle you can more then 16'' of travel out of a 14'' coilover. Read billvistas article in the coilover bible, as it explains it rather well. Thus mounting position can add to suspension travel. The 14'' and 16'' of the actual shock travel will only directly correlate to suspension travel if the coilover are mounted vertical.
jeeper8650 is offline   Reply With Quote
Old 03-26-2008, 11:30 AM   #4 (permalink)
Drive slideways
Member # 81214
I know the tricks to coil mounting. That's not the question.
Again,
Is working for the extra 2" of travel worth it? It can be made up in mounts and the like. But assume is a vertical mounting on the front of a TJ.
Old 03-26-2008, 11:32 AM   #5 (permalink)
Rotten Sperm
Nordic1's Avatar
Member # 63386
Winnar
Mounting your shocks at different angles will help with more flex
Just keep in mind that the higher the angle, the less effective the dampener will be
So || will dampen better than /\ but /\ will outflex ||
I'll see if I can fish up some pics when I am not in class
Nordic1 is offline   Reply With Quote
Old 03-26-2008, 12:17 PM   #6 (permalink)
Drive slideways
Member # 81214
I'm apperantly not able to put to words what I'm thinking.
Jeep TJ, front shock, verticle instalation. A 14" CO will go in without cutting the fenders and moving a lot of engine crap. A 16" CO can be made to fit. Is there a benefit to all the work other than the 2" of travel? does having 13" of down make that much of a difference over 11" of down?
What real world diference will the extra 2" make?
Don't make any assumptions about the question please. It is what it is.
Old 03-26-2008, 12:24 PM   #7 (permalink)
Blackjeep2's Avatar
Member # 98545
I am facing the same thing right now- - - I am buying Co's in the next day or two and still have not made up my mind on 14's or 16's -- - seem like alot of work involved for just 2 inches.... lets here your thoughts--- mine is a daily driver -- but I still get down in the rocks - - which way should I go.
Blackjeep2 is offline   Reply With Quote
Old 03-26-2008, 01:45 PM   #8 (permalink)
Member # 78458
I would think having 2'' more travel would make a difference. Flex is over rated on the trail. Balance of flex and stability is more important than RTI busting flex, IMO.
Old 03-26-2008, 06:02 PM   #9 (permalink)
Drive slideways
Member # 81214
Yep, top secret. Then again the concept might be too deep for the PBB
Old 03-28-2008, 07:17 PM   #10 (permalink)
Member # 72567
Pat, you should go wheeling with me sometime. I share the same principals as you do as far as lift height and drivetrain tricks. Long live the D30 with big tires.
Personally, I wouldn't bother with the 2", since your 4 link rear will probably pick up the slack. Not to mention the more stealth it will be. Do you run a sway bar offroad? If you do, then you definately won't notice.
Donald
dmarsingill is offline   Reply With Quote
Old 03-28-2008, 10:22 PM   #11 (permalink)
Diablo169's Avatar
Member # 63382
Send a message via AIM to Diablo169
I have 16" Fox coil overs. It is more work to mount them, I had to cut my rear tub and extend the front upper links into engine compartment.
As far as I'm concerned I have way to much flex, but thats how I like it. I sit pretty high but with only 4" up travel I can stuff my 37s into to fenders.
--- 80 Proof --- TJ Juggy Build
"14 Bolt don't give a shit. It takes what it wants."
-Little Sluice Memorial Weekend 2012
Diablo169 is offline   Reply With Quote
