Axle Shaft Replacement - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-23-2008, 01:14 PM   #1 (permalink)
Member # 112346
When you change out your axle shafts do you have to grease the new shafts before putting them back in?
Mefford816 is offline   Reply With Quote
Old 04-23-2008, 01:34 PM   #2 (permalink)
WeBilt 4x4
JDunn's Avatar
Member # 33065
I don't, they should come greased.
79' CJ7 Buggy
KI6TLZ
WeBilt 4WD Club
JDunn is offline   Reply With Quote
Old 04-23-2008, 07:07 PM   #3 (permalink)
Little Jeep's Avatar
Member # 58117
What Jeep? What axle? Are you asking about the axle shafts themselves, or the hubs that go on the axle shafts? Axle shafts do not get greases, just be careful to hold axle shaft to center of axle seals as you slide them in. The hubs are non servicable.
Little Jeep is offline   Reply With Quote
Old 04-23-2008, 07:13 PM   #4 (permalink)
Member # 78458
No you dont need to grease the axle shafts.
Jeep
jeeper8650 is offline   Reply With Quote
Old 04-24-2008, 09:30 AM   #5 (permalink)
WeBilt 4x4
JDunn's Avatar
Member # 33065
I decided he was talking about the u-joints in some front shafts?
79' CJ7 Buggy
KI6TLZ
WeBilt 4WD Club
Old 04-27-2008, 11:54 AM   #6 (permalink)
Member # 75018
On a model 20 and dana 44 semi float rear axle shafts , the wheel/axle bearings are in between an inner and outer seals .The inner seal keeps the axle oil inside and the outer axle/wheel seal keeps outside crap out and GREASE in the wheel/axle bearing . So if this is what you have , then yes , pack the axle bearing with grease before installing shaft into housing .
'69 Jeepster charity case rockcrawler :imagined
pyrocrat is offline   Reply With Quote
