8.8 flange - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-17-2008, 08:45 PM   #1 (permalink)
Member # 108456
8.8 flange
I just got an 8.8 from a 98 Explorer and I got the driveshaft with it. The driveshaft has the flange that bolts onto the axle. Is this the same flange that I would have had to buy if the axle hadn't come with the driveshaft? I believe the one I need is for the 1310 u-joint correct? I guess what I'm asking is if this flange is for the 1310 ujoint. Thanks.
dannyz14 is offline   Reply With Quote
Old 05-17-2008, 09:39 PM   #2 (permalink)
Member # 30600
I think that flange is for a 1330 ujoint, but I'm not positive. I also think you could use that flange and a 1310 x 1330 conversion ujoint with a 1310 driveshaft. I haven't personally done this, so I'm not positive.
Conversion u joint at advance:
http://www.partsamerica.com/ProductD...rtNumber=10134
or :
http://completeoffroad.com/i-123005-...onversion.html
99tantj is offline   Reply With Quote
Old 05-17-2008, 10:27 PM   #3 (permalink)
Member # 63585
Yes, you can use it, but as stated above you have to use the 1310 (stock u joint size) to 1330 (stock 8.8 u joint size) conversion u joint. I had them install one on my new driveshaft.
[img]http://img225.imageshack.us/img225/4295/ssignature9af.jpg[/img]
98 TJ 2" RE lift, 33" MTZ's on black and silver wagon wheels, custom intake with K&N filter, 2 100w KC's on bumper, 100w H4 headlight conversion. Currently down...as usual.
tjmudpuppy is offline   Reply With Quote
Old 05-18-2008, 11:39 AM   #4 (permalink)
Member # 108456
Awesome thanks guys I appreciate it.
Old 05-18-2008, 12:21 PM   #5 (permalink)
Member # 22824
You can also use a flange from a V6 Ford Ranger w/8.8 rear. It uses the 1310 joint.
[COLOR="red"][B]You can say what you want about the South, but you never hear of anyone retiring and moving North[/B][/COLOR]
Georgia Mike is offline   Reply With Quote
