Does any one make rear upper control arm brackets for a TJ? Mine were starting to tear off at the welds a couple of months ago. So I welded them back on. Now the brackets are bent all to hell. So I am looking for a heavy duty complete replacement bracket. I see that Currie sells pieces to add to existing brackets but I am looking for complete brackets.
Rubicon Express sells complete axle bracket kits, u may be able to buy just the pieces you need. Also have you tried Gen-Right or Poly Performance? They generally have a good selection of parts like that. Also you may want to try some of the after market axle companies like SOLID, Dynatrac, Currie etc. They also usually have full axle bracket kits that they may be willing to part out for ya. Hope this helps, good luck.
Had the same problem. Called Ballistic for there INNER FRAME MOUNT bracket. They have to make a custom bracket. $38 shipped the San Diego.
this bracket is close to stock bracket BUT 1/4" thick.
Ballistic 1-520-888-4441
