I was wanting to know if a pitman arm from a Waggy will fit the steering gear output shaft from a CJ7? I just swapped in a d44 front from a 75 Waggy into my 86 CJ7 and the drag link end is way too big to fit into the hole on my CJ7's pitman arm. If I got the hole machined bigger in order to fit the drag link end there would be no metal left around the hole. So, I am triying to see what my options are to make this work? I figured the best place to start was to see about the Waggy one fitting.
