I just purchased a 79 CJ7 with a fiberglass tub. It is pretty well built. The main issues I have are the e-brake cables were cut at the rear drums. They look like they must have been pretty well rusted to the point of no return so I assume the guy just did not want to deal with them. I have been parking the Jeep in gear (3-speed) but want something that I can park and leave it running.
My concern is that mounting the traditional emergency brake pedal will interfere with my front cage. I am also concerned that mounting the foot pedal to the firewall may be too much for the fiberglass to handle. The tub is steel reinforced, but I just don't want to damage anything.
Has anyone mounted a TJ style handbrake on the trans tunnel? Is there a good handbrake to mount under the dash? If you have mounted the traditional pedal to the firewall I would like to know how it works.
Also, what do I need as far as cables go? I guess I need the entire set up. Is there a kit that can be purchased with mounting brackets and all?
Any pics of your setups would be greatly appreciated.
