AMC20 axle locker intstall problem - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-02-2008, 07:45 PM   #1 (permalink)
njjeep's Avatar
Member # 89925
i went to put new alloy axle one piece axles along with an aussie locker in my amc20. i installed the locker first which went in fine than i put in the driver side axle and it went in fine also. it took a couple good hits with a hammer to get it to fully seat. when i went to put in the driver side it would not go in at all. so i took the locker apart and pulled the axles out again. the side gears are really tight going over the splines i cant even get the side gear on over the passenger side (even after hitting it with a hammer) axle but the stock spider gears slide right on. any suggestions or comments appreciated.
njjeep is offline   Reply With Quote
Old 06-02-2008, 07:56 PM   #2 (permalink)
Member # 80155
try the drivers side shaft in the side of the locker that wont go??..that should be the proof
I feel more like now then I did a while ago
runemuck is offline   Reply With Quote
Old 06-02-2008, 08:16 PM   #3 (permalink)
njjeep's Avatar
Member # 89925
i cant since the driver side is shorter than the passenger side
Old 06-02-2008, 08:24 PM   #4 (permalink)
Member # 80155
sorry I thought you had it back out...I guess I am as lost as you..the obvious..have you compared the splines??sorry i am not more help
Old 06-02-2008, 08:39 PM   #5 (permalink)
nhgpnut's Avatar
Member # 42521
Send a message via AIM to nhgpnut Send a message via Yahoo to nhgpnut
You should definitely not need a hammer. Call the vendor, sounds screwed up to me. The new splines will be tighter but not that tight. Slide your old shaft in to the locker and see if it fits the splines.
If you have it, a truck brought it. Without trucks,you would be naked and hungry.
nhgpnut is offline   Reply With Quote
Old 06-02-2008, 08:41 PM   #6 (permalink)
njjeep's Avatar
Member # 89925
yeah the splines are the same i guess in need to contact aussie locker to see why the side gears are so ridiculously tight going over the splines
has anyone have this or have not had this problem with any aussie
Old 06-02-2008, 08:48 PM   #7 (permalink)
nhgpnut's Avatar
Member # 42521
Will your old axle shaft slide into the locker?
Old 06-02-2008, 09:10 PM   #8 (permalink)
njjeep's Avatar
Member # 89925
i dont know i will check tomorrow
thanks for the help.
if its the locker i might just put the spider gears back in and lincoln lock it for now
Old 06-03-2008, 09:40 AM   #9 (permalink)
njjeep's Avatar
Member # 89925
i did some tests today.
the original spider gears slide on the old axles and the new alloy axles with no effort.
the Aussie locker side gears slide on the old axles fine but they do not want to slide over the splines of the new axles even when hitting them on with a wooden block.
so now i am really confused
Old 06-03-2008, 01:01 PM   #10 (permalink)
jeeperman19's Avatar
Member # 79589
I have the Aussie and superior axles in my junk, all went in smoothly...maybe try running your old shafts for a little while to loosen up the locker???
84 cj8 4.0/AW4/D300, locked f&r........yet so much crap to do
jeeperman19 is offline   Reply With Quote
Old 06-03-2008, 02:26 PM   #11 (permalink)
Member # 108872
Send a message via AIM to MonsterSeven Send a message via Yahoo to MonsterSeven
i say put your aussie back in. with your axles still out, do a side by side comparison of the splines, the length, etc. put your 2 pieceers back in there and loosen up the locker for the break in period which is 500 miles i believe. good luck.
*98 RHD TJ: swapped 4.0L/AX-15/Dana 300, 4.88, AEV 3", LP9"/S88, Grizzly/Detroit, OTK steering, 35" muds... 84:1.
*85 CJ-7: GM350/NV4500/D300, SOA on Wags, LP44/LP9", Aussies, 37" MT/Rs, Staun beadlocks, hi-steer, 110:1... in pieces.
MonsterSeven is offline   Reply With Quote
Old 06-03-2008, 02:57 PM   #12 (permalink)
njjeep's Avatar
Member # 89925
doesnt the locker part of the aussie break in not the splines that accept the axles.
also my brake backing plates are now pressed on my new axles and i would have to buy new bearings for the 2 piece axles which i dont want to do.
my friend suggested putting the axles in a deep freezer overnight and trying to put them in the morning
Old 06-03-2008, 03:47 PM   #13 (permalink)
Member # 80155
Have you talked to Bill at aussie or the axle people?? I am getting ready to put in a aussie so I am following this
Old 06-03-2008, 03:54 PM   #14 (permalink)
njjeep's Avatar
Member # 89925
i emailed aussie today and alloy says since my stock gears slide on fine it is the locker. so we will see what aussie says tommorow.
i might just take a file to the splines i need to get these axles in.
Old 06-04-2008, 09:33 AM   #15 (permalink)
Member # 80155
whats the latest??
Old 06-04-2008, 02:05 PM   #16 (permalink)
Member # 114479
I wouldn't freeze the axles. If you ever need to get them back out you'd have to heat the locker while it's still installed.
Second place is a body bag- Carlos Hathcock
Warpig58 is offline   Reply With Quote
Old 06-04-2008, 02:13 PM   #17 (permalink)
Member # 65332
Sounds like the locker is a tad to small. Use emery cloth to open it up about .005, and do the same to the shafts, basically hone it.
Should work, make it happen.
fishotro is offline   Reply With Quote
Old 06-04-2008, 02:45 PM   #18 (permalink)
aussielocker's Avatar
Member # 19383
a
The problem is that these Moser aftermarket axles have a slightly different ramp on the axle spline than the OEM axle design and since the Aussie Locker is a precision locker and designed around the tolerances of an OEM axle, the Moser is incompatible with the locker. In the past we have seen communications from Moser indicating they had a manufacturing issue at some point with AMC20 axles, but we are not suggesting that this is what is going on here as that would be up Moser to confirm or refute. But the Aussie Locker is within spec.
aussielocker is offline   Reply With Quote
Old 06-04-2008, 02:55 PM   #19 (permalink)
njjeep's Avatar
Member # 89925
raining today so i got nothing done but i will be trying the emery cloth tomorrow and i will report back asap
Old 06-04-2008, 03:13 PM   #20 (permalink)
Member # 108872
that might void the warranty of the aussie locker...
Old 06-05-2008, 01:32 AM   #21 (permalink)
Member # 65332
MosterSeven is probably right.
I really don't know what to tell you, if it where me, I would hone it. But I run welded spider gears.
I do plan on an aussie up front later though.
Old 06-05-2008, 07:18 PM   #22 (permalink)
njjeep's Avatar
Member # 89925
finally got them to slide right in.
I filed the axle splines, than used 350 sandpaper and wire wheeled the splines until they where smooth.
thanks for all of the advice.
