im curious which way you would run this steering set up. im changin the thing soon but for now this is it... difference it the TRE that connects the drag link and tierod
that's a pretty good DL angle, which can always cause wobble... have U thought about flipping it? from what I could tell from the pic, looks like ya have a DPA already???
Would you consider taking off the Knucles, ream them from the topside to accept a 1-ton TRE, stronger steering, better steering angles, higher tie rod, without doing a full blown highsteer?? Only thing you would have to do is make a new tie-rod. and buy 40 bucks worth of TREs
run it the first way with some poly spacers between the tre and the knuckle gets rid of a lot of play and is a good temp fix.. Im running it like that on my xj and it works...
well im usin the stock axle mount and as you can see its amed up. would be hard to at the tie rod. why does it matter tho... they both go side to side with the steering.
