Ok i need a little help my pinion bearings are worn out an since i'm inside the housing i want to rebuild the axle the ring gear an pinion gears are still good a little pitting due to water entering the diff the ring gear is worn on the outer edge of the teeth due to the pinion not being in the correct position.I'm need to rebuilding axles so any help with this would be greatly appreciated also whats the easiest way to remove the carrier bearings.
