Guys about to start my soa on my 95 yj. Got my kit for the 8.8 and also the front perches from ruffstuff. Realized afterwards I ordered straight perches for the 30 and the factory are offset. Am I boinked and need to reorder or is there a way around it?
If they are tall enough you could cut one "leg" of and weld it underneath to make it offset. If they are low perches, you should get the right ones.
Travis..
All time BAD idea. Aluminum shims crack real easily and fall out leaving you with loose u-bolts. :shaking: If you're going to use any shims use steel.
