cheapo front TJ brakelines - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-03-2008, 08:14 PM   #1 (permalink)
Member # 87845
I dont wanna drop $100 on a set of fancy braided stainless extended brake lines.
call me cheap. thats fine, I can take it
ive seen a handful of posts on a handful of boards recomending various brakelines from various models...
the most promising seem to be leads towards mid 90s GM 3/4 ton trucks. Looking on Napa's site, I see a slew of different part numbers depending on 2wd vs 4wd, cab configuration etc etc...
any one got a specific part number they recomend?
y2knole is offline   Reply With Quote
Old 07-03-2008, 09:18 PM   #2 (permalink)
Member # 97809
I use some made for a '95 YJ. ...they're about 3" longer than stock.
Flash- '00 TJ is offline   Reply With Quote
Old 07-04-2008, 07:02 AM   #3 (permalink)
Member # 56176
1/2 ton chevs. 6-7 inches longer than TJ's.
- Auto Sense: BH177760
- Wagner: 116846
- Midas: 2201
- Auto Spec: 86043
- Bendix: 77760
- NAPA #38620
Curt's_97 is offline   Reply With Quote
Old 07-04-2008, 08:35 AM   #4 (permalink)
Member # 87845
- Wagner: 116846
- Midas: 2201
- Auto Spec: 86043
- Bendix: 77760
- NAPA #38620
thx a ton!!!
Old 07-04-2008, 02:21 PM   #5 (permalink)
Member # 115187
Originally Posted by y2knole View Post
thx a ton!!!
Let me know where you find I could use a pair my self. Thanks
-[B]Mike[/B]
_____________________________________________
My Build - [B][URL="http://www.pirate4x4.com/forum/showthread.php?t=782142"]Burrellsjeep Project: Eugene[/URL][/B]
[URL="http://www.pirate4x4.com/forum/showthread.php?t=804177"]Heavily MOGified - Justin's Build
[/URL]
[B][URL="http://www.youtube.com/mburrell007"]My Videos[/URL][/B]
burrellsjeep is offline   Reply With Quote
Old 07-04-2008, 02:59 PM   #6 (permalink)
Jason Johnson's Avatar
Member # 115536
A long time ago and in a galaxy far far away, I took some front brake lines from a 77 CJ-7 with drum front brakes and screwed them into the frame end of the stock brake line, but this was on a CJ, and the TJ may be metric. But you could go to Auto Zone and look at the TJ line and the CJ drum brake line to see if it will work.
Jason Johnson is offline   Reply With Quote
Old 07-04-2008, 03:01 PM   #7 (permalink)
Member # 115536
And I saw that jeep recently with the same getto rigged double brake line some 15 years latter, and it is still working!
Old 07-04-2008, 07:55 PM   #8 (permalink)
Member # 87845
will do, I'm gonna hit the local NAPA first thing tomorrow morning and see if that part number washes out
Old 07-05-2008, 01:02 PM   #9 (permalink)
Member # 115187
Hey found this on Napa's website, It looks like it might just work. There almost 25 inches long compared to 18 inch TJ Line.
http://www.napaonline.com/MasterPage...e+-+Left+Front
-[B]Mike[/B]
[/URL]
Old 07-05-2008, 01:29 PM   #10 (permalink)
Member # 56176
Trust me, it works for left and right. I have them on my heep.
Old 07-05-2008, 01:44 PM   #11 (permalink)
Member # 115187
Do you know if the dodge 1/2 ton will work Napa part# UP 380295, There 34 inches long.
http://www.napaonline.com/masterpage...e+-+Left+Front
-[B]Mike[/B]
[/URL]
Old 07-05-2008, 04:58 PM   #12 (permalink)
Member # 56176
What the hell would you want 34" lines for. They'd be draggin on the ground. LOL. I just used the 1/2 ton chevs and moved the hard line to the inside of frame. Here's a little flex with lotsa room to go.
Old 07-05-2008, 09:27 PM   #13 (permalink)
Member # 115187
Good point, What steering setup are you running? Tie rod and so on.
-[B]Mike[/B]
[/URL]
Old 07-07-2008, 06:52 AM   #14 (permalink)
Member # 56176
Still the stock ford stuff with some bracing
