Dana 60 front lug pattern - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-04-2008, 03:36 PM   #1 (permalink)
Member # 85860
How hard would it be to convert a newer Ford D60 front with the 8x170mm pattern to the old 8x6.5" pattern to match a rear axle I just got? What all would have to be swapped?
I looked in tech and the 60 bible and didn't see anything about it.
Edit- Just out of curiosity, would most of ya'll think a 2001 DRW Ford high-pinion D60 would be worth $500? That's what the guy wants for the front I'm looking at.
"You got it Dan, I'm retarted." - Why J?
StinkyMcStink is offline   Reply With Quote
Old 07-04-2008, 05:23 PM   #2 (permalink)
ItsaCJ6's Avatar
Member # 6340
Location: Telluride CO, within site of of Black Bear Pass
But the older shit knuckles out.. or have yours filled and drilled. or ......buy new wheels.
Marc
In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good."
Super conversion calculator website
Love and kisses, Zaphod..
ItsaCJ6 is offline   Reply With Quote
Old 07-04-2008, 05:36 PM   #3 (permalink)
Member # 85860
So just have the hubs filled and re-drilled and get new rotors/calipers to match? I want to run the same wheels on all 4 corners.
Old 07-04-2008, 05:38 PM   #4 (permalink)
ItsaCJ6's Avatar
Member # 6340
Sorry about the typos...BBQ, 4th July, Beer. I am sure can understand.. There people here who have welded them up and had them re drilled... Seams like a lot of work, when you can just go to the yard and get the parts you want.
Marc
Old 07-04-2008, 05:42 PM   #5 (permalink)
Member # 85860
So the hubs off an 8x6.5" will bolt right onto there? The actual hub itself is the only difference? If so, that's be excellent.
Old 07-04-2008, 05:55 PM   #6 (permalink)
ItsaCJ6's Avatar
Member # 6340
Knuckles out get it all...
Marc
Old 07-04-2008, 07:53 PM   #7 (permalink)
Member # 85860
I gotcha. Thanks man.
Old 07-04-2008, 08:27 PM   #8 (permalink)
Banned
trkklr77's Avatar
Member # 29016
the older shit being the ttb 50/60 outer correct,
then you get the non unit bearing spindles and normal locking hubs as well as the bolt pattern.
Old 07-04-2008, 08:32 PM   #9 (permalink)
Member # 85860
I think I'm gonna hold out for an older one. That one would still have balljoints plus I'd have to buy the parts to make it match.
