YJ build- TCASE options - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-05-2008, 03:21 PM   #1 (permalink)
Member # 40690
I recently picked up a YJ for a low buck build.
It came with the peugot tranny and matching tcase, which was shot.
I picked up an AX15 and NP231 to replace the existing setup. I also have a good Dana 300 in the garage.
The plan is to upgrade the front axle to a waggy Dana 44, and my question is this.
Would I be better off with-
A) The AX15/NP231 with an 80's driver drop waggy axle
or
B) The AX15/Dana 300 with a 70's passenger drop waggy axle.
1990 4Runner, 4" procrap lift, 4.88 gears, Arb locker rear, Detroit Trutrac front, 33" MTs
littlejohn is offline   Reply With Quote
Old 07-05-2008, 03:27 PM   #2 (permalink)
ky scrambled's Avatar
Member # 85771
300 over a 231 everytime. Get the adapter/clocking ring and clock it flat. You are gonna have to "massage" the floor a little bit and grind a little on the 300 though.
Play stupid games, win stupid prizes
ky scrambled is online now   Reply With Quote
Old 07-06-2008, 01:19 AM   #3 (permalink)
torquefreak's Avatar
Member # 89757
I say get a doubler kit and use both!!
AX15/NP231/d300 with with a passenger drop front axle.
/forum/motor-tranny-t-case-performance/399755-version-2-planetary-crawlerbox-adapters.html
Team Feaux X Feaux
LouisianaClubChallenge.com
torquefreak is offline   Reply With Quote
Old 07-06-2008, 05:56 AM   #4 (permalink)
Member # 85771
$500 and I still need to get a SYE...Ill pass. I Just put a 4to1 in the 300.
Old 07-06-2008, 07:46 AM   #5 (permalink)
Member # 40690
Actually you don't need an SYE with that setup- the Dana 300 is in the rear.
BUT- what if I put that in my CJ- that already has a LOMAX 4:1 gearset.
Hmmnh- 2.72 x 4 = 10.88 to 1 in the tcase!
I can hear Dana 44 axles popping all over the place!
Old 07-06-2008, 07:49 AM   #6 (permalink)
Member # 85771
I looked at the picture too fast.
shit I can hear my 44 axles popping and its still on the jackstands
Old 07-07-2008, 05:51 AM   #7 (permalink)
Member # 40587
I have a T-18 with a 6.32:1 first gear, 4.10s and a Dana 300 with a 4:1 kit, approx 104:1 crawl along with 36" bias Iroks. I beat mine mercilously, ive had minimal issues (spit a u-joint cap out which warped the axle ears), no chromo shafts or super-joints. Just gotta be careful with the skinny pedal when approaching full lock. Unless you are running a rediculously large tire, i doubt you will have major issues if you know when and where you can get stupid with your stuff Good Luck
[QUOTE=Dieselmh]I'll cave his fucking head in with a shovel, just to show him that just because he has opposable thumbs, that doesn't put him on the same badassedness level as humans. Stupid arrogant possums. :shaking:[/QUOTE]
The Black Sheep is offline   Reply With Quote
Old 07-07-2008, 07:00 PM   #8 (permalink)
Member # 40690
Well, I chose option (B) AX15 with Dana 300 with 70's waggy Dana 44.
I picked up a complete '76 waggy today for $300!
Been sitting for while, time to see if engine runs. Supposedly ran great until the kid lost interest 5yrs ago and parked it.
Might throw that 360 into the mix as well!
