Member # 99055
ford 8.8...5:13s...center pin?
hey everybody
well we just finished a friends 8.8 rear and he used 4:56s. we had to get a notched X-pin to work with the gears. i dont really want to use a notched one because theyre weak. but even with the 4:56s it looked like we would have to cut into the contact pattern if we shaved a tooth or 2 down. so 5:13s being even thicker would be worse. is it possible with this gear ratio to grind a little tooth or am i stuck with the notched pin?? if anybodys got any pics of theirs that would help a lot..thanks |
New Beginnings
Member # 99513
I was just wondering, why don't you assemble the diff and install the center pin THEN install the ring gear on the carrier.
Thats how I do it on my Dana differentials. But I have to admit, never worked on a Ford 8.8. So if there is something I don't know about, free to flame me or teach me.
My jeep is a hotrod! /forum/jeep-hardcore-tech/658004-going-against-odds.html ![]() NEW BEGINNINGS: /forum/general-4x4-discussion/971511-jealle-o-cigano.html |
Member # 99055
^^that works with non c-clip axles.
with the ford 8.8 you have to pull the center pin out, push the shafts in, install the c-clips, and then put the center pin in. with the center pin in you dont have enough room to push the shafts in to install the c-clips |
#6 (permalink) | |
New Beginnings
Member # 99513
Thanks for schooling me. I did read in my differential book that it is ok to grind a little away for clearencing for a center pin.
My jeep is a hotrod! http://www.pirate4x4.com/forum/showthread.php?t=658004 ![]() NEW BEGINNINGS: http://www.pirate4x4.com/forum/showthread.php?t=971511 |
