Member # 117360
Exciter Wire on CJ7 Alternator
1986 Jeep Cj7 with I-6 258 and Delco style alternator. I am getting a slight continuity reading on my Fluke meter between the Alternator exciter wire and the ground. (The 18ga. brown wire coming out of the top of the ALT).
- Is this a sign that the internal voltage regulator on the ALT is going bad? - The exciter wire goes from the ALT back into the ignition wiring circuit. What is the exciter wire actual for?
Give em' the Purple Nurple! |
Member # 117360
I have been told that I DO need the exciter wire in the circuit. Although if anyone has any specific info on the exciter wire I would be interested in hearing your thoughts.
Give em' the Purple Nurple! Last edited by MTing!; 08-13-2008 at 09:13 AM. |
Member # 34804
When you start your rig the exciter wire is energized and starts the charging circuit on the regulator, if you do not have it, your alternator will never charge. Think of it like an "on" switch. Aftermarket companies do make one wire self exciting alternators for GM applications that do eliminate the exciter wire though.
1947 Willys |
