lifter? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-23-2008, 08:49 PM   #1 (permalink)
Member # 116164
lifter?
I have a 92 Jeep wrangler. I know that straight six's are notorious for loud lifters when they start up. Mine has always done that when it hasn't been run for a while. But today I noticed that every time I put it in drive it sounds like a lifter is getting loud. If I put it in natural and rev it the sound seems to go away. Has anyone else had this problem and if so any recommendations on fixing it would be appreciated?
bnjwrangler is offline   Reply With Quote
Old 08-23-2008, 10:03 PM   #2 (permalink)
Member # 108872
Send a message via AIM to MonsterSeven Send a message via Yahoo to MonsterSeven
what does your oil gauge read?
*98 RHD TJ: swapped 4.0L/AX-15/Dana 300, 4.88, AEV 3", LP9"/S88, Grizzly/Detroit, OTK steering, 35" muds... 84:1.
*85 CJ-7: GM350/NV4500/D300, SOA on Wags, LP44/LP9", Aussies, 37" MT/Rs, Staun beadlocks, hi-steer, 110:1... in pieces.
MonsterSeven is offline   Reply With Quote
Old 08-23-2008, 10:24 PM   #3 (permalink)
Member # 116164
I've got good oil pressure. I didn't know if there is some kind of oil additive or something I should try?
Old 08-23-2008, 10:53 PM   #4 (permalink)
ta2oodfreak's Avatar
Member # 118825
Send a message via AIM to ta2oodfreak Send a message via Yahoo to ta2oodfreak
well, i would make sure somthing else isnt making noise, such as a belt driven accessory or pulley. if you come back to the lifter you can try a 1/2 qt of mopar atf +4 in the oil and run it for a few days. the detergents in the atf may clear a restricted passage in or to the lifter. if that doesnt work, gear up for a day project.
good luck
TREC series #44B
" Auto racing, bull fighting, and mountain climbing are the only real sports ... all others are games."
- Earnest Hemingway
Thanks to.....
Automedic-AMPCars.com
Paintball Explosion-PBBomb.com
ta2oodfreak is offline   Reply With Quote
Old 08-24-2008, 06:44 AM   #5 (permalink)
Member # 108872
get a long screwdriver, put it against your ear, and hold it on the engine in different places. this should pinpoint where your problem is.
Old 08-24-2008, 07:12 AM   #6 (permalink)
Member # 116164
thanks
Old 08-24-2008, 09:17 AM   #7 (permalink)
Member # 118825
just keep free of moving parts.
TREC series #44B
- Earnest Hemingway
Thanks to.....
Old 08-24-2008, 02:53 PM   #8 (permalink)
Member # 114810
What kind of oil filter are you running? Fram?
engnmonkey is offline   Reply With Quote
Old 08-24-2008, 04:09 PM   #9 (permalink)
Member # 90393
it don't matter, i've tried fram VS wix vs others.........still the same KNOCK in my 4.0 AND my lifters in the old 258
(i truely believe the FRAM being junk is BS, and YES i've read reports such as this):
http://www.knizefamily.net/minimopar...lterstudy.html
rockrknockr is offline   Reply With Quote
Old 08-24-2008, 06:22 PM   #10 (permalink)
Member # 110248
mavel mystery oil
Western Maine Mountain Jeepers
A shortcut is the longest distance between any two points
djljeep is offline   Reply With Quote
Old 08-24-2008, 06:23 PM   #11 (permalink)
Member # 114810
The 140k mile 4.0 in my YJ had a lifter tap for years. After trying atf, Marvel Mystery oil, STP, and a bunch of other things, I decided to live with it.
I recently swapped to a Purolator plus filter and the tap is gone. I'm not saying it will work for you, just that is how I got rid of my 4.0 tap.
