extending links - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-05-2008, 06:39 AM   #1 (permalink)
Member # 69410
Send a message via AIM to 1stgenxxx
extending links
I have 4.5 springs on the front of my XJ. I need to extend my links to get my caster back to where it should be. What kinda formula do I need to follow to get how much longer they need to be? Thanks
89 x-cab 40"s sbc/th350/205 RIP
01 Rattle box, 98 Cherocar
1stgenxxx is offline   Reply With Quote
Old 09-05-2008, 07:32 AM   #2 (permalink)
Member # 87845
im in the same boat.
Im going to start with an FSM and a harbor freight angle finder this weekend.
alot easier than trying to do the crazy math.
y2knole is offline   Reply With Quote
Old 09-05-2008, 08:06 AM   #3 (permalink)
BlueTorch's Avatar
Member # 14529
Umm... here is how I would do it. I would have the vehicle on the lift with the coils removed and lifted to ride height. I would removed the links that need to be changed. I would set my caster anlge where I needed it. Measure how long the link needed to be, and build a new one.
This would be difficult to do if you have the coils in. You also need to make sure you have the vehicle sitting at ride height before measuring. Make sure the axle stays centered when the links are removed. If you are adding to both upper and lower links. Be sure to set the wheelbase desired and then measure for caster second.
That is the super simple way of doing it.
Dan
Blue Torch FabWorks, Inc.
205-521-7333
www.BlueTorchFab.com
"Like" us on Facebook!
www.facebook.com/bluetorchfab
BlueTorch is offline   Reply With Quote
Old 09-05-2008, 02:29 PM   #4 (permalink)
Member # 69410
I was looking at my jeep today and actually nocied a "bow" in my springs. I can tell by looking at the coil spring that the axle isn't sitting in the right angle and it's pushed backwards
thanks for the info
