Front rear for a tj - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-06-2008, 02:46 PM   #1 (permalink)
Newbie
Member # 117890
Front rear for a tj
I need to know what yr cherokee front rear will fit under a 06 wrangler? and what i have to do to it. i got a sweet deal on a smashed 06 wrangler and the rear is bent. i heard that a cherokee rear will work. please let me know
heretilltheend is offline   Reply With Quote
Old 09-06-2008, 02:52 PM   #2 (permalink)
Member # 40587
Im not sure about cherokee axles, but why just limit your selection to them? Why not a Ford 8.8/D30 combo? or even a matching set of Waggy D44s? Is this gonna be a wheeler or just a flip it and sell it project?
[QUOTE=Dieselmh]I'll cave his fucking head in with a shovel, just to show him that just because he has opposable thumbs, that doesn't put him on the same badassedness level as humans. Stupid arrogant possums. :shaking:[/QUOTE]
The Black Sheep is offline   Reply With Quote
Old 09-06-2008, 02:56 PM   #3 (permalink)
Newbie
Member # 117890
dd i already have a trail rig i have that combo in my 92 wrangler spool in the rear and a limited slip in the front
Old 09-06-2008, 03:14 PM   #4 (permalink)
Arizona_Jeep's Avatar
Member # 99818
I would do 8.8 because they are cheap, same bolt pattern, and easy to come by. No axle will bolt dirrectly in. Actually, I take that back, get a rear Rubi D44 or a D44 from a Sahara if you want a bolt it upgrade. Simple and cheap.
Beer is good: Jeep CJ7, under contruction....again
Nobama 08'
Arizona_Jeep is offline   Reply With Quote
Old 09-06-2008, 03:19 PM   #5 (permalink)
Newbie
Member # 117890
i dont need a rear rear i need a front rear. the jeep was smashed and it a salvage title. i need to get it inspected and i cant find a tj rear around me. thats why im looking into a cherokee front rear with the same gears. im a welder so i could move brakets thats not a problem.
Old 09-06-2008, 04:41 PM   #6 (permalink)
Drive slideways
Member # 81214
95-00 for non-disco.
There were some earlier non's also. I've seen them back to 89
edit
typo its 95-00 (beer kills my tyoing)
Never Monday is offline   Reply With Quote
Old 09-06-2008, 05:17 PM   #7 (permalink)
Newbie
Member # 117890
thank you
Old 09-06-2008, 08:48 PM   #8 (permalink)
2JSC's Avatar
Member # 118939
Not all Sahara's have D44's. It was a common upgrade that most Sahara buyers went for but not all.
2JSC is offline   Reply With Quote
Old 09-06-2008, 08:58 PM   #9 (permalink)
Member # 99818
yeah, forgot that, should have realized that after seeing some without it. seems pointless to get a sahra without the d44.
sorry for typos, damn stomche is killing me
Nobama 08'
Old 09-07-2008, 07:43 AM   #10 (permalink)
FootWithNoToes's Avatar
Member # 98085
I'm actually in the middle of doing this swap right now. The cherokee hp 30 is a direct bolt in, but the brake calipers are different. I'm swapping the outers off of my lp 30 onto the hp to retain the calipers. I'm not sure of the years w/o the vacuum disco, but mine was out of a 98 xj and does not have it.
FootWithNoToes is offline   Reply With Quote
Old 09-07-2008, 08:49 PM   #11 (permalink)
2JSC's Avatar
Member # 118939
I believe 93 or 94 was the last year for CAD on the XJ D30's.
Old 09-08-2008, 07:41 AM   #12 (permalink)
Member # 81828
A cherokee/xj rear will work, typical axles in the rear are the 8.25 with 27 spline shafts on the older models, and 29 on models after mid 1997. Some xj rears are dana 44 which are kind of sought after by the xj crowd, I only see them for sale every once in a while around here. They are the same wms as a tj, so if you are comforatble swapping mounts over, then it would be easy. You can either cut them off the old axle but chances are if it was hit that hard they may be bent. Rubicon Express sells some mount kits, I was just looking at them and I think the whole setup was around 300 bucks. Unless you plan on flipping the tj for a quick buck or driving the jeep to work and back, stay away from the dana 35 (rubber fill plug, oval shaped), they are ok for street use on stock tires, but will leave you stranded offroad.
ptowntj is offline   Reply With Quote
Old 09-08-2008, 07:54 AM   #13 (permalink)
Member # 3483
Not sure what's going on in this thread, just wanted to point out that both "front rear" and "rear rear" have been used in this thread...
Benny
350/350/205/60/60/linked/locked/lowered
Bigger Valves is offline   Reply With Quote
Old 09-08-2008, 08:09 AM   #14 (permalink)
Member # 80155
Originally Posted by bigger Valves View Post
not Sure What's Going On In This Thread, Just Wanted To Point Out That Both "front Rear" And "rear Rear" Have Been Used In This Thread...
X'2
I feel more like now then I did a while ago
runemuck is offline   Reply With Quote
Old 09-08-2008, 08:06 PM   #15 (permalink)
Skerb's Avatar
Member # 36943
Send a message via AIM to Skerb
hahhahahhaah...a rear is only a rear when its in the rear. WTF is a front rear...its a front dif man or a front diferential, or a front axle...anything but a front rear, thats like a dick vagina or a front asshole...
For info on outdoor adventures in and around South Carolina check out OffroadSC.com
Skerb is offline   Reply With Quote
Old 09-08-2008, 09:51 PM   #16 (permalink)
Member # 17632
I can't believe it took 13 replies before someone said something Even after 2 people misunderstood and had to be corrected that he wants a "front rear". I understand this forum is flame free, but Jeeeezzzz
Travis..
74 Ramcharger, 360, 4spd, 60/70 on 37s
91.5 Dodge 6BT 5 spd tow rig
crashnzuk is offline   Reply With Quote
Old 09-08-2008, 10:36 PM   #17 (permalink)
Member # 73968
thats f-n funny. i still want an explanation on the front rear.
bassbelly is offline   Reply With Quote
Old 09-09-2008, 05:57 PM   #18 (permalink)
Member # 17632
Don't cha know all diffs are called rear ends? I guess since a 203 t-case has a differential you'd call it the center rear.
Travis..
Old 09-11-2008, 05:02 AM   #19 (permalink)
Member # 118083
Travis..
overly complicated bumble-fuck explanation.
Sup, nigs
mrdiameter™ is offline   Reply With Quote
Old 09-11-2008, 05:56 AM   #20 (permalink)
Member # 40587
Who the fuck are you again newbie??? What kind of relevant info did you just offer in this post? You have 7 posts so far and you are already flaming people, in a newbie forum none the less? Why don't you read more and post less, maybe look in the dictionary for a word called sarcasm, learn it then go castrate yourself with a fucking blender, asshat.
