Member # 91319
stak vs atlas II
pros and cons....
who has what and what are you opinions on which one is better?? just trying to get a idea of who has ran what and which might be better for my set up... thanks |
Member # 40587
Both are good companies. Id try to pony up for the 3 speed verisons. I don't run one personally but Ive heard nothing but good things about each of them for what my opinion is worth. Unless somebody comes on with some specific examples I would say get what suits your project the best in terms of gearing, options and cost.
[QUOTE=Dieselmh]I'll cave his fucking head in with a shovel, just to show him that just because he has opposable thumbs, that doesn't put him on the same badassedness level as humans. Stupid arrogant possums. :shaking:[/QUOTE] |
I run a stak 3speed, 3:1 & 5.4:1 low ranges. It works good. I've had it for about 2 years still little hard shifting, leaks a little. I think either one is a good choice, atlas has been around so there seems to be less issues, but stak for the money is good product.
07' Jim's Garage narrowed rockwell buggy |
Member # 91319
i believe its the 48RH... 5.2 grand cherokee...
im still learning about the driveline as i go with my project... and i have narrowed it down to a stak or atlas for the t-case and just trying to get some input on what people are happy with... im more looking at the atlas II 3.8:1 but i want to hear what people have to say for stak... from what i hear its just about the same thing just a little cheaper... thanks for all the input so far... keep it coming... |
Member # 119931
I run a twin-stick Atlas II, GM 700R4, HESCO 4.7 stroker. The Atlas has been run hard and only maintenance so far is replacing a tailshaft seal. Either one is a good choice, maybe it will come down to price.
Super Six Last edited by mountaineer06; 09-14-2008 at 11:29 PM. |
Drive slideways
Member # 81214
The STaK Monster box is huge. About an inch larger in all dimensions than the Atlas. If you can afford it the 3 spd is the way to go with an auto. Other than shifters that are cantankerous and a few seeping leaks the STaK is bullet proof.
Resident Beekeeper
i have a stak, and i really like it. the guys at stak are great people to deal with.
A government big enough to give you everything you want, is a government big enough to take everything you have. My Reverse Flow BBQ Pit Build http://www.pirate4x4.com/forum/gener...pic-heavy.html |
#10 (permalink) | |
Member # 79098
Have you seen the new Stak Mini Monster? It's smaller than the original Monster box and available in a 2 speed and 3 speed. http://stak4x4.com/products_tcase.htm ![]()
1993 Wrangler 2006 Dodge Cummins |
Member # 47826
The AtlasII & 4 speed have synchros wich allow it to shift on the fly.
In 2.0/1 low range I can shift to high range @ 40+ MPH. In 4.3/1 I shift to high @ 20 MPH Put the trans in neutral and shift the case from low to high.
Thean Bellocchi [URL="www.polyperformance.com"]www.[COLOR="Red"][B]P[/B][/COLOR]oly[COLOR="Red"][B]P[/B][/COLOR]erformance.com[/URL] [email]Thean@PolyPerformance.com[/email] |
#12 (permalink) |
Member # 47888
Atlas has been great to work with and they have the ancillary stuff needed to finish the job if you have non-typical installation issues. (Weird adapters, shifters, etc.) Their tech line is super.
WTF-J - WTF gives you freedom. Freedom brings opportunity. Opportunity makes your future. |
#14 (permalink) |
Member # 119162
With a 5.2 and automatic, you would be fine with an Atlas II. V-8 torque and proper axle ratios will give you decent crawling power. I run an Atlas II 3.0 in my xj with 4.56 gears and an auto and never lack for power. If you go too low in your tc ratio, you'll find that when you need wheel speed it's not there.
#17 (permalink) | |
Member # 119931
X2 ~ this is a great feature. plus, if you didnt already know, if you disengage the rear diff on the fly and run front wheel drive only you'd be amazed at how the front wheels will drag you over and through ruts that you just can t make with the rear diff engaged... then on the fly you re-engage the rear diff. unless you have rear steer it like the rear wheels just want to go straight instead of following the front wheels... anybody else ever try front diff only on hard lines ?
Super Six Last edited by mountaineer06; 09-16-2008 at 04:35 AM. |
#19 (permalink) | |
Member # 15447
I started out planning on buying a STak, but I couldn't get them to answer an email, so I bought an Atlas. NIB
KEEP PUBLIC LANDS PUBLIC!!!! - VOTE OUT A FAWKIN' DEMOCRAT!!!! Last edited by NIB-98TJ; 09-19-2008 at 08:10 PM. |
#20 (permalink) |
Member # 91319
thanks for the info.. and i am planning on changing all that in the 1st place, im going to stretch the wheel base so i would need new DS anyway
there wont be much jeep left of my jeep when it comes out of the shop the way i see it... it was a jeep thing but all that shit broke... Last edited by ultimate97TJ; 09-20-2008 at 07:38 AM. |
