Member # 10410
Weak Hydro Assist...
Not sure if this belongs in newbie, but maybe it will get a look.
Running stock YJ pump, with tapped box (saginaw). Running 1/4" hydro lines, to a 1.5x8x1 ram. Control/steering is fine if it is not bound up or in the rocks, but it just has zero power once that happens. All the other systems I have seen turn when mine won't. Any ideas? Rest of the specs are in sig... Thanks
'91 YJ "Short Bus" |
Member # 17632
If it won't turn when in a bind, you have a low pressure problem. Maybe the relief in your pump is set-up really low, or it's bad. If you have a way or know someone with a way, you can tee in a pressure gauge on the pressure line from the pump and see what the pressure is at full lock and compare it to the spec (don't know off the top of my head what it is).
Travis..
74 Ramcharger, 360, 4spd, 60/70 on 37s 91.5 Dodge 6BT 5 spd tow rig |
Member # 23452
i haven't done it but, we had a friend with the same problem and he said he had to drill out the fitting on the pump. now agin i never done it and cant explain the details but after he did this is was perfect, jason.
93 yj 4.0 700r/241 HP 60 front 5.38's, Chevy 60 rearsteer 5.38's, bolth spooled and beating it like it owes me money. |
