my attempt at a skid plate
its not finished but may help some new guys
ok, so we all know the TJ TC (transfer case) skid hangs to low, and aftermarket skids cost alot, building your own is nice and cheap, but what to do about those bolts? get ride of em? but need to remove it still so cant weld it. here is the fix, i went to the local metal shop and ordered a piece of steel was 54" by 24" of 1/4" plate (its a little wide cause i wanted the extra for gussets for new cage) i then took measurement in rear of frame (bout 2" behind rear bolt hole) then went 24" toward the front and took that measurement (since frame narrows) then i took these measurements and marked them on the plate and since i have access to a 112 ton press at work i had guy i work with bend it on my marks to 90 degrees, ending up with this ![]() ![]() i then measured height of frame and location of the body mount and cut them out and trimmed skid down ![]() then with skid in place i drilled 3 holes on each side, and added some grade 8 bolts and ended up with this ![]() ![]() now i dont have this finished but i will added some steel tube in the holes of the frame to keep it from crushing (i will weld it but not needed, just easier to install) and for now i drilled holes in bottom of skid and trans bolts just hang below but i will end up building a cross member like this one, and i will weld some 1" angle on top edge of skid in a "^" pattern to help with bracing, hope this helps, as of now i have $110 in steel, $30 in drill bits (broke one so really only $20, and burnt one up due to no cutting oil so could be $10) and $15 in bolts/washers/nuts, new muffler is needed since OEM hangs below skid ![]() , and a SYE will be needed if you have ANY lift since this accounts for a 3" lift in your driveline, you will need BL as well, or a tub massage, i have 2" BL and it clears fine
Lifted & cut up TJ, 06 Cummins QCLB 6spd 4x4 Need TJ cage welded & 4:88s installed near Ft Stewart Last edited by dzntzhellfire; 12-11-2008 at 04:49 PM. |
Member # 40587
THats a nice beefy looking skid. The only problem that you are gonna run into (and you can easily change it) is once you start wheeling, if you don't get some tubing to re-inforce that skid its gonna get beat to shit and warped really bad. Maybe you said you were and I missed it, if so i appologize. They work really well, you just need to re-inforce it really well since at times you could be slamming the entire weight of the vehicle on it.
[QUOTE=Dieselmh]I'll cave his fucking head in with a shovel, just to show him that just because he has opposable thumbs, that doesn't put him on the same badassedness level as humans. Stupid arrogant possums. :shaking:[/QUOTE] |
#4 (permalink) | ||
right now im trying to just get it on the road, its been down since may with motor swap (blew another 2.5 so i swapping in a 4.0) and its my DD, just glad co-worker lives close
Lifted & cut up TJ, 06 Cummins QCLB 6spd 4x4 Need TJ cage welded & 4:88s installed near Ft Stewart Last edited by dzntzhellfire; 12-11-2008 at 06:42 PM. |
Member # 40587
You are gonna want more then angle iron. You should consider getting some DOM or square tube. I have 1-1/4" DOM tubing with 3/16" plate and mines all beat to shit. I can barely attach the skid plate any more. My rig gets used but I don't wail on it mindlessly either. Its your build, you can do what you want, but based on what my skid looks like, my guts telling me you are gonna be redoing it again after a few good wheeling trips if you don't put some serious re-inforcement in it.
Good Luck to you.
[QUOTE=Dieselmh]I'll cave his fucking head in with a shovel, just to show him that just because he has opposable thumbs, that doesn't put him on the same badassedness level as humans. Stupid arrogant possums. :shaking:[/QUOTE] Last edited by The Black Sheep; 12-11-2008 at 07:56 PM. |
#7 (permalink) | |
reread there will be bracing, and lots of it
Lifted & cut up TJ, 06 Cummins QCLB 6spd 4x4 Need TJ cage welded & 4:88s installed near Ft Stewart |
