transfer case passanger drop yj - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-15-2009, 07:11 PM   #1 (permalink)
Member # 82114
I've got a mostly stock drivetrain in a 95 yj and am thinking of putting a set of cucv axles in, I'm curious what is a decent bolt up transfer case with pass drop, I'm aware of the d300, anything else that bolts up?
I'm planing on getting a atlas down the road, but I would like to split the drivetrain /axle builds to be lighter on the wallet...
fjmf is offline   Reply With Quote
Old 01-18-2009, 07:44 PM   #2 (permalink)
Member # 75018
If you have 23 spline t/case input ,which you should ,a dodge 208 from 80's 1/2 ton or a ramcharger ,should bolt up .
It will be a tight fit on the frame rail on passenger side though ,so measurements should be done ahead of time .
That case ,the 208 , will be plenty strong.
'69 Jeepster charity case rockcrawler :imagined
pyrocrat is offline   Reply With Quote
