Member # 99310
8.8 to 6 lug
bought a waggy 44 for my tj and im wantin to make my 8.8 match my 44. Is there some adpaters out there that change 5 on 4.5 to 6 on 5.5 that is not a 2 peice? Ive been lookin for a while let me know if anyone has found anything cuz i dont really wanna get shafts but might have to break down and buy em if i cant find another solution
2001 TJ on Reds |
Member # 99055
adapt it usa makes a set of adapters. i was in your same boat. with that pair of axles, and getting the lug pattern to match. the way i saw it
convert the waggy 44 to 5X5.5. which would be about 200 in parts, and then still need some adapters to make the 8.8 5X4.5 to 5X5.5, which was another 100. or buy the adaptitusa adapters for 200. it saved me 100 bucks, and was a lot easier the converting the waggy 44 to 5 lug, and either way youll need new wheels |
Member # 99310
thanks iwishihad1. ive thought about changin over to 5 lug but in the long run it would be easier to find parts if i just changed it over to 6 lug. im about to check out adaptitusa now
2001 TJ on Reds |
Member # 59753
Just get new alloy axles in the bolt pattern you want, It's not like they cost eleventy billion dollars. Then you'd have matching fronts and rears and no fuckin adaptors.
[QUOTE=ChevyGal;9752200]I personally think it's cool Janet Reno likes to wheel. :)[/QUOTE] Last edited by Alfred W.; 02-10-2009 at 10:23 AM. |
Member # 84882
If you get shafts I would like to know who you have build them. I would like to buy a set as well. I have no Idea how much it would cost.
I just did the same swap and I have the 2 piece wheel adapters. I don't trust them with 37 inch tires. I think switching the front over to 5 lug might cost as much as a set of custom shafts, especially if you have to get new rims. |
Member # 99310
well i called dutchman motorsports and they had some with bearings and all for right at 400 bucks. i also called alloy usa but the person i talked to didnt help to much. they asked me if i knew they sold 6 lug 8.8 shafts or not. but im thinkin i might just goto 5 on 5.5
2001 TJ on Reds |
