Member # 130105
Jeep D30
I have no expierence with jeeps and was wondering if this axle could hold up to 34 ltbs? If its going to snap axles constantly I could just as easily keep replacing d28 axles in my Ranger but came across a D30 for a descent price.
Ranger is trail truck only and is going to be beaten with some aggression. No real rock crawling just hill climbs and off camber washout type of stuff mostly loose dirt and mud. Motor is a 2.9 v6 with 5 speed.
"TO BE OLD AND WISE YOU MUST FIRST BE YOUNG AND STUPID" |
Member # 80641
here is the answer to your question... maybe.
it depends on how your drive... if your locking the axle. One my best friends has a 97 tj on 35s with stock axle shafts and arbs front and rear. He has never broken an axle. But he is also a very smooth driver. If you have a selectable locker up front you can unlock it when you dont need it and this lowers the stress the axle sees. You said alot of mud... this means in my mind not alot of traction. this allows you to get away with more. What would i do? I would skip the dana 30, even though i know they are almost a perfect fit for you, and go to a dana 44. The 44 has been used in so many applications that there must be one that will for you. With a 44 you could romp on it all day for years with 34s and not break anything.
[QUOTE=beater82;10779355]You should try patriotism. That stuff can fuck some shit up.[/QUOTE] [QUOTE=DillWeed;9324924]Kid... you are looking for a dance club and you stumbled into an old school tavern full of mean drunks...Run for your life.[/QUOTE] 1990 yj, 44/60, d300, howell FI- sold |
#4 (permalink) | |
Member # 130105
"TO BE OLD AND WISE YOU MUST FIRST BE YOUNG AND STUPID" Last edited by Midget28; 03-28-2009 at 11:04 AM. |
Member # 130105
Not a clue its out of a 97 TJ (whatever that is) and it has 4:10 gears. I know zero about Jeeps so idk what style that would be but Ive heard raves and rants about them and figure pirate oughtta hold the more honest opinion without all the brand loyalty.
#7 (permalink) | |
Drive slideways
Member # 81214
Look for one out of a small Cherokee. |
Member # 130105
Thats what I meant if its going to bust axles constantly I could just as easily keep replacing the TTB BS the ranger has while I wait for a good deal on a 44.
Member # 112788
Dude a D35 BOLTS in, and is nearly as strong as a D44 and you can get them CHEAP. Don't bother with a turdy.
Locked and LTB'd BII. Last edited by HahnsB2; 03-28-2009 at 07:09 PM. |
#12 (permalink) | |
New Beginnings
Member # 99513
Please ellaborate.To the OP, A front 30 with Chromos and quality u-joint will hold up to 34's. Just don't get stupid with the skinney pedal. You really want a HP30 which can be found in the Cherokee's or YJ's. I ran a HP30(built to the hilt) in my YJ on 36's with zero issues. I just had to be carefull on the skinney.
My jeep is a hotrod! /forum/jeep-hardcore-tech/658004-going-against-odds.html ![]() NEW BEGINNINGS: /forum/general-4x4-discussion/971511-jealle-o-cigano.html |
#13 (permalink) |
do these guys know that the newer rangers run a D35 center section up front with the IFS?
i wouldnt bother unless you get the TJ D30 with spare shafts.
*98 RHD TJ: swapped 4.0L/AX-15/Dana 300, 4.88, AEV 3", LP9"/S88, Grizzly/Detroit, OTK steering, 35" muds... 84:1. *85 CJ-7: GM350/NV4500/D300, SOA on Wags, LP44/LP9", Aussies, 37" MT/Rs, Staun beadlocks, hi-steer, 110:1... in pieces. |
#14 (permalink) | |
Member # 112788
Locked and LTB'd BII. Last edited by HahnsB2; 03-28-2009 at 10:56 PM. |
#15 (permalink) | |
Member # 130105
I was looking for a alternative to the 35 ttb b/c well it sucks lol bolt in or not its still more hassle than a solid axle to maintain. That being said Ill prolly just go that route so this thread can die off.
"TO BE OLD AND WISE YOU MUST FIRST BE YOUNG AND STUPID" Last edited by Midget28; 03-29-2009 at 12:15 AM. |
#16 (permalink) | |
Drive slideways
Member # 81214
#17 (permalink) | |
#18 (permalink) |
Member # 120280
if you go with a D30 and keep buying axles you are going to spend more money than you would buying d44. You said you had an 8 lug D44 just switch to ford 5lug outters and your good.
