What do I have? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-21-2009, 06:55 PM   #1 (permalink)
Member # 134401
Send a message via MSN to Manitobamudman
What do I have?
Im totally new to Jeeps and have no idea what I have in this truck.
Its a 76 J-10 Jeep truck with a 4.2l I6 with a 3spd manual transmission and a manual shift transfer case.
Can anyone tell me from experience:
What axles are under this truck?
What transfer case I have
Will a 318/360 bolt up to this tranny?
Will a GM or Ford motor bolt up to this tranny?
What transmissions will bolt up to this transfer case.
Sorry for the absoulte nooblet post but im totally lost when it comes to Jeep/Chrysler products.
Thanks in advance.
Also I might be able to locate a vin of some sort.
Manitobamudman is offline   Reply With Quote
Old 04-21-2009, 07:17 PM   #2 (permalink)
Member # 80641
a vin number would be a huge help for the guys that know about these trucks... it tells you exactly whats in the truck. Also if you buy a red star and post up some pictures of the drivetrain im sure people will be able to help you.
[QUOTE=beater82;10779355]You should try patriotism. That stuff can fuck some shit up.[/QUOTE]
[QUOTE=DillWeed;9324924]Kid... you are looking for a dance club and you stumbled into an old school tavern full of mean drunks...Run for your life.[/QUOTE]
1990 yj, 44/60, d300, howell FI- sold
offroadjunkie is offline   Reply With Quote
Old 04-21-2009, 07:25 PM   #3 (permalink)
Member # 134401
I can probably get numbers off all the parts.
Its just that that Jeep is at the farm and I'm in town.
Bogger: 1976 J-10 35x12.5x15 BFG MT's
DD: 2006 GMC Sierra 1500
Old 04-22-2009, 11:38 AM   #4 (permalink)
kingmick217's Avatar
Member # 44327
Send a message via MSN to kingmick217
A simple search renders Jeep specifications
Originally Posted by IndyCJ View Post
Wagoneer, Grand Wagoneer, and J-Series Trucks
Description
* Built from 1971 - 1991
* All built on SJ platform
* Models
o Wagoneer, Grand Wagoneer (1971-1991)
o J-10, j-20 Truck (1971-1987)
o Cherokee (2 door and 4 door (1974-1983)
* The Cherokee was introduced in 1974 as a lower cost alternative to the more luxurious Wagoneer
* The Cherokee Chief variation offered wide track axles (65.5" instead of 59.2"). The Honcho was a truck but had the same wider axles.
ENgines
* AMC 258 cu in I-6 (1971-1987)
* AMC 304 cu in V-8 (1971-1973)
* AMC 360 cu in V-8 (1971-1991)
* AMC 401 cu in V-8 (1974-1987)
Transmissions
* Warner T-14A 3 speed manual (Wagoneer: I-6 1971-1979)
* Warner T-15A 3 speed manual (Wagoneer and Trucks: V-8 1971-1979)
* Warner T-18 4 speed manual (Wagoneer: 1971-1979, Trucks: 1971-1987)
* Tremec T-176 4 speed manual (Wagoneer and Trucks: 1980-1986)
* GM TH-400 3 Speed Automatic (Quadra-trac: 1971-1979)
* Chrysler 727 3 speed automatic (Wagoneer: 1980-1991, Trucks: 1980-1987)
Transfer Cases
* Dana 20 2-speed part time (1971-1979 manual)
* Command-trac: NP 208 2-speed Part-time (1980-1991)
* Selec-trac: NP 229 2-speed part-time/full-time (Optional 1983-1986)
* Quadra-trac: NP 228 2-speed full-time (optional 1985-1991)
* Selec-Trac: NP 242 2-speed part-time/full-time (optional 1987-1991)
* quadra-trac: BW 1339 1-speed or 2-speed full-time (1971-1979 automatic)
* Quadra-trac: NP 219 2-speed (optional 1980-1985)
rear Axle
* dana 44 (Wagoneer and 1/2 ton truck: 1971-1975, wide tracks: 1974-1983, Grand wagoneer: 1987-1991)
* amc 20 (Wagoneer and 1/2 ton truck: 1976-1986)
* dana 60 (3/4 ton and 1 ton trucks: 1971-1987)
front axle
* Dana 44
yep
Oh you sir. You are definitely fired.
kingmick217 is offline   Reply With Quote
Old 04-22-2009, 12:03 PM   #5 (permalink)
Member # 44327
that is the best guess as to what you have.
The Dana 20 is a cast iron transfer case, having a passenger-side front output and a centered rear output. It has the same "Texas" front mounting input flange as does the Dana 18.
http://www.pirate4x4.com/tech/billav...ue/jpbhsgs.pdf
that should get you what else you need.... Canadians
Old 04-22-2009, 03:35 PM   #6 (permalink)
Member # 134401
Sorry I'm new.
How strong is the dana 44 and amc 20?
What would be the max tire size you'd recommend?
Old 04-22-2009, 05:46 PM   #7 (permalink)
Member # 17632
No Chrysler product engine will bolt up to this set-up without an adapter or modified bell housing. AMC stuff is NOT the same as Chrysler stuff. You can put damn near any engine in front of any trans if you spend enough time or money. Personally, I wouldn't waste my time adapting a 3 speed trans to anyting. Use the set-up as-is or get something entirely different.
Travis..
74 Ramcharger, 360, 4spd, 60/70 on 37s
91.5 Dodge 6BT 5 spd tow rig
crashnzuk is offline   Reply With Quote
Old 04-22-2009, 05:56 PM   #8 (permalink)
Member # 134401
well what v-8 would be a direct bolt up to this transmission?
or what tranny would directly bolt up to this transfer case.
thats more of the question
Old 04-22-2009, 07:54 PM   #9 (permalink)
Member # 17632
Any AMC V8 form 70? up will work with the bell housing. I would imagine any trans that accepts or can be adapted to the texas pattern t-case would work.
Travis..
Old 04-23-2009, 03:49 PM   #10 (permalink)
Member # 134401
what chevrolet trans would fit up to this transfercase witohut an adapter?
Old 04-23-2009, 04:10 PM   #11 (permalink)
Member # 44327
http://www.novak-adapt.com/knowledge/model_20.htm
Chevrolet Model 20
A version of the Dana 20, though rarer, found its way into 1969-1973 Chevrolet Blazers. They were much less common than the NP205 and NP203. We have seen one Dana 20 in a Chevrolet truck with the TH400, but there is no documentation to support this being a factory combination.
Old 04-23-2009, 04:13 PM   #12 (permalink)
Member # 134401
hmm
i wish i knew what the hell i was talking about then I wouldnt look so dumb
Is there a chart with adapters or something that I can look at?
Old 04-23-2009, 04:19 PM   #13 (permalink)
Member # 44327
Just click on this link and you will find the info you need.
I don't like using adapters and crap myself either, but it does not apear you're going to have a cheap easy route. It may be better to just get a whole donor truck and swap the entire drive train if you have to go chevy.
Old 04-23-2009, 05:01 PM   #14 (permalink)
Member # 134401
its just that I have numerous chevrolet motors and trans kicking around so using an adapter would be very cheap for me if it ended up working
Old 04-23-2009, 05:10 PM   #15 (permalink)
Member # 134401
wow 620 bucks to convert the trans and motor to my transfercase
thank god that case is bullet proof
Old 04-23-2009, 05:20 PM   #16 (permalink)
Member # 134401
I think i might have a 150 according to this site?
here is my jeep finally lol
Old 04-23-2009, 05:43 PM   #17 (permalink)
Member # 17632
I assume you want to ditch the 258 for more power in the mud? If so, you'd be better off getting a chevy trans/transfer case combo to go with your Chevy engine. You should have a lot of room in that J truck for nearly any trans/t-case combo. It would be cheaper and easier since there would not be any aftermarket adapting.
Travis..
Old 04-23-2009, 06:08 PM   #18 (permalink)
Member # 134401
you are 100% correct on my purpose
wouldnt changing my drive train make me need to get new drive shafts?
Old 04-26-2009, 02:13 PM   #19 (permalink)
Member # 115187
Oh It will,
You can have drive shaft shop cut and balance it for about $50 a shaft.
-[B]Mike[/B]
_____________________________________________
My Build - [B][URL="http://www.pirate4x4.com/forum/showthread.php?t=782142"]Burrellsjeep Project: Eugene[/URL][/B]
[URL="http://www.pirate4x4.com/forum/showthread.php?t=804177"]Heavily MOGified - Justin's Build
[/URL]
[B][URL="http://www.youtube.com/mburrell007"]My Videos[/URL][/B]
burrellsjeep is offline   Reply With Quote
Old 04-27-2009, 09:44 PM   #20 (permalink)
Member # 17632
I just saw an AA adapter in the classified section that mates an SM465 to a Dana 18/20. Might be worth a look.
Travis..
