D60 balljoint knuckle damaged? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-30-2009, 11:08 AM   #1 (permalink)
Austin4x4's Avatar
Member # 124844
so my question to you guys is do you think this knuckle will hold up on the trail? you can see where it is ground down compared to the other side. the truck it came out of drove fine when the axle was pulled. can i repair this or what are my options for replacing the knuckle.
thanks
[IMG][/IMG]
[IMG][/IMG]
2005 TJ Unlimited 4.7L Stroker, 35's. eventialy 1 tons and 40's
Originally Posted by TJVigilante View Post
if 20 people in a row tell you that you're a fucking idiot, maybe you should head back to school.
Austin4x4 is offline   Reply With Quote
Old 04-30-2009, 12:02 PM   #2 (permalink)
Member # 103442
Send a message via AIM to GreatWhiteXJ
My guess is it wouldnt last long. The ground area makes that portion very ceceptible to crack. I would keep it for a spare.
Options for aftermarket knuckle:
Off Road Unlimited
Donahoe Racing
Solid Axle
Theres a few other but those are the only one's Id recomend. Good luck.
XJ on 42's
GreatWhiteXJ is offline   Reply With Quote
Old 04-30-2009, 12:04 PM   #3 (permalink)
2003_ram's Avatar
Member # 127313
Go to a junkyard, or find a takeoff from somebody who went to the exspensive aftermarket knuckles.
Nobama, I don't mind working for my money, you shouldn't either.
Willys Build http://pirate4x4.com/forum/showthread.php?t=824952
“If you don't have time to do it right, when will you have time to do it over?”
- John Wooden RIP
"Let every man have a pistol, instead of one man have a tank."
2003_ram is offline   Reply With Quote
Old 04-30-2009, 01:36 PM   #4 (permalink)
Austin4x4's Avatar
Member # 124844
ya i new i was going to replace it. just wanted a second oppinion. i got the axle for free because of the damage, so i would like to keep with the cheap theam. im guess try the junkyards first.
Old 04-30-2009, 01:59 PM   #5 (permalink)
Member # 103442
What are you intending to do exactly? Just replace the factory knuckle? If you intend on hi-steer at anytime or hyrdo assist look at the after market list I gave you. The ORU knuckle is $300 and you only need the passenger side.
BTW...seeings how were are relatively close to each other, if in fact you do find a junkyard with Super Duty 60's....PLEASE PM me and let me know. Thanks.
XJ on 42's
Old 04-30-2009, 03:00 PM   #6 (permalink)
Austin4x4's Avatar
Member # 124844
the solid axle knuckles aren't a bad price but then you have to buy the highsteer arms, so they get pricy. what to you meen i only need the passenger side? the driver is the one that is damaged
Old 04-30-2009, 10:30 PM   #7 (permalink)
Member # 103442
OK... I missed that being the driver knuckle. My bad. So first replace that. Get a stocker. Now what I ment by only needing one is, the Super Duty Knuckles are already drilled for OTK. Which technically only matters if you intend to use TRE's, but since the tie rod is aleady reamed top down, you already have enough clearance provided use you something other than a factory tie rod. IE, build your own.
The ORU knuckle you would get give you 2 mounts....one for TR and one for DL.... The drag link being the one you'll desire to correct your angles. Now this all depends on your height and how you choose to set-up your steering. For all I know I could have just babbled 5 minutes for something you dont need. But, if your say 5-6" or bigger than this knuckle is gonna be your friend.
XJ on 42's
Old 05-01-2009, 09:44 AM   #8 (permalink)
Austin4x4's Avatar
Member # 124844
ok i get you now i looked at the ORU knuckle. too bad my passenger isnt the damaged one, and too bad ORU dosnt make a driverside. i am planing on doing a Y link setup for my sterring. i dont want to fork over the cash for a pair of knuckles sience i only need one.
on a side note i was planing on having my jeep 1ton by the fall, but i got laid off last week. so maybe by next spring .
