Aussie break-in - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-07-2009, 10:03 AM   #1 (permalink)
Member # 124369
Aussie break-in
I put an Aussie in the D44 rear of my '86 CJ-7. Ran it ~100 to 150 miles, then decided to take the cover off, and check everything out. The locker's parts look exactly like they did the day I put them in, minus the red grease. The only problem I noticed was some talcum-powder fine metal pieces like glitter in the oil that came out.
Is this part of break-in and normal wear or is something wrong with my install? Tolerances measured at install were within range, but were very tight.
landscraper is offline   Reply With Quote
Old 06-07-2009, 10:53 AM   #2 (permalink)
Member # 108872
Send a message via AIM to MonsterSeven Send a message via Yahoo to MonsterSeven
after 100-150 miles of turning left and turning right, ratcheting and unratcheting, there is bound to be some metal in there. you would have broken some teeth by now if it wasnt in there just right. i think you are fine.
*98 RHD TJ: swapped 4.0L/AX-15/Dana 300, 4.88, AEV 3", LP9"/S88, Grizzly/Detroit, OTK steering, 35" muds... 84:1.
*85 CJ-7: GM350/NV4500/D300, SOA on Wags, LP44/LP9", Aussies, 37" MT/Rs, Staun beadlocks, hi-steer, 110:1... in pieces.
MonsterSeven is offline   Reply With Quote
Old 06-07-2009, 12:29 PM   #3 (permalink)
Member # 40587
You are fine. Put the cover back on, top it off and run it.
[QUOTE=Dieselmh]I'll cave his fucking head in with a shovel, just to show him that just because he has opposable thumbs, that doesn't put him on the same badassedness level as humans. Stupid arrogant possums. :shaking:[/QUOTE]
The Black Sheep is offline   Reply With Quote
Old 06-08-2009, 03:47 AM   #4 (permalink)
Little Jeep's Avatar
Member # 58117
What break in? I installed mine, went wheel-n
Little Jeep is offline   Reply With Quote
Old 06-08-2009, 05:59 AM   #5 (permalink)
Member # 59753
Put a large flat magnet in the bottom of your diff. you are ALWAYS going to have metalic particals in the Diff oil.
[QUOTE=ChevyGal;9752200]I personally think it's cool Janet Reno likes to wheel. :)[/QUOTE]
Alfred W. is offline   Reply With Quote
Old 06-08-2009, 06:17 AM   #6 (permalink)
Member # 99055
normal...your next change you shouldn't see as much metalic flaking, but your good....and X2 on the "what break it" of the 6-7 ive installed out break in/test is a long hill climb
iwishihad1 is offline   Reply With Quote
Old 06-08-2009, 01:03 PM   #7 (permalink)
Member # 124369
I guess break-in was the wrong way to phrase it. Its a long way to the trails from where I live so I either take the Jeep to the dog park and such or it sits parked. It did get tested immediately at the new subdivision going in next door. Its my first locker so I was obviously pleased
Thanks for the input-
