Tj Advise? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-20-2009, 09:27 AM   #1 (permalink)
Spy
TayJ's Avatar
Member # 106637
Tj Advise?
So I am getting ready to do my stretch in the rear of my Tj. I want to move the axle back around 6 inches. At the same time I want to remove the track bar, build a truss and triangulate the upper links.
The plan is:
*use the same frame mounts I am using now.
*cut off the upper coil buckets and move them back farther.
*new driveline.
*box in the tank with thick plate incase it comes in contact with rocks.
As far as the front goes I am going to cut the sliders down to match the tub and begin building tube fenders that will have more clearance for the tires. After the rear stretch is done I plan on stretching the front axle forward an inch or two and making it a three link with one upper and a track bar.
I want to focuse on the (*) stuff first.
I need to know what joints, hiems, bushing, etc... to use on my four links. What type of steel and how thick, etc... Can I cut, butt weld in a pice of steel and sleeve the lowers. And whatever else you can think of. Think budget also.
99 tj, kingpin 60 / 10.25, 42" rockers, project
99 yukon, motor done, tranny done, needing tons and tires and "which front axle is better with leaf spring" advice.
90 shadow 1100cc dd
TayJ is offline   Reply With Quote
Old 06-20-2009, 09:28 AM   #2 (permalink)
Spy
TayJ's Avatar
Member # 106637
Pictures
90 shadow 1100cc dd
Old 06-20-2009, 09:31 AM   #3 (permalink)
Spy
TayJ's Avatar
Member # 106637
I also did quit a bit of searching to find some answers but alot was still unanswered.
90 shadow 1100cc dd
Old 06-20-2009, 09:37 AM   #4 (permalink)
Spy
TayJ's Avatar
Member # 106637
A few more:
90 shadow 1100cc dd
Old 06-20-2009, 11:11 AM   #5 (permalink)
Member # 85098
what are those lower links made from?
ruecifur is offline   Reply With Quote
Old 06-20-2009, 11:14 AM   #6 (permalink)
Spy
TayJ's Avatar
Member # 106637
Solid stock with threads machined into them. The main section of the links are 1 3/4" stock. At the time I thought it was a good idea but it really have very limited flex but I feel that is due to the stock uppers.
90 shadow 1100cc dd
Old 06-20-2009, 11:20 AM   #7 (permalink)
Member # 131356
i like the custom gas tank relocation how long did it take you to make that?
raze1287 is offline   Reply With Quote
Old 06-20-2009, 11:26 AM   #8 (permalink)
Spy
TayJ's Avatar
Member # 106637
It took about a half hour to move the tank. I removed the tail gate and hammered the seams down for clearance. I had to get new fuel hose to reach but the wiring harness reached with some slack. The tank project is not done though, I will remove the straps and build some tank protection. I had to keep the rear seat for my son.
90 shadow 1100cc dd
Old 06-20-2009, 12:05 PM   #9 (permalink)
Member # 115187
How do you feel about having a plastic tank full of gas that close to your son?
-[B]Mike[/B]
_____________________________________________
My Build - [B][URL="http://www.pirate4x4.com/forum/showthread.php?t=782142"]Burrellsjeep Project: Eugene[/URL][/B]
[URL="http://www.pirate4x4.com/forum/showthread.php?t=804177"]Heavily MOGified - Justin's Build
[/URL]
[B][URL="http://www.youtube.com/mburrell007"]My Videos[/URL][/B]
burrellsjeep is offline   Reply With Quote
Old 06-20-2009, 12:11 PM   #10 (permalink)
Spy
TayJ's Avatar
Member # 106637
I don't see a problem with it. It maybe plastic but it holds the fuel in. What problems do you see with it?
90 shadow 1100cc dd
Old 06-20-2009, 12:21 PM   #11 (permalink)
Member # 115187
When mounted under the jeep there is a fire wall between you and the tank. If something were to happen and the tank catch fire. What if you layed jeep on its side or rolled.
Is it still street legal?
-[B]Mike[/B]
[/URL]
Old 06-20-2009, 12:28 PM   #12 (permalink)
Member # 85098
that link system looks sketchy as fuck. But next to the ghetto ass tank relocation, it seems to be right in place. Fix both of those if you're planning on putting your kid in that thing
Old 06-20-2009, 12:35 PM   #13 (permalink)
Spy
TayJ's Avatar
Member # 106637
The tank is going to be fully inclosed in a metal box. The links work right now, just not well. The jeep has a long ways to come still and on a budget.
New links? I want to make this thinkg better, not focus on the stuff that I know needs changed.
"I need to know what joints, hiems, bushing, etc... to use on my four links. What type of steel and how thick, etc... Can I cut, butt weld in a pice of steel and sleeve the lowers."
90 shadow 1100cc dd
Old 06-20-2009, 01:00 PM   #14 (permalink)
Spy
TayJ's Avatar
Member # 106637
So for safety would a metal box around the tank be better than a fuel cell or visa versa? Behind the seat is the only place I have to put it.
90 shadow 1100cc dd
Old 06-20-2009, 01:12 PM   #15 (permalink)
Member # 115187
I am in the same boat,
I have two sons that wheel with me, after debating cell, no cell, I just opted to keep the tank under the jeep. Thats just me though.
People wheel with cells in there jeeps all the time, I don't know that I have ever heard of any one getting hurt.
So I think a fuel cell would be ok, If you go trying to box it in your going to have a hard time getting it fit.
-[B]Mike[/B]
[/URL]
Old 06-20-2009, 01:14 PM   #16 (permalink)
Spy
TayJ's Avatar
Member # 106637
It won't be hard to make it fit.
90 shadow 1100cc dd
Old 06-20-2009, 01:21 PM   #17 (permalink)
Member # 115187
As far as links, I would build all new ones.
I am using flex joints, I am really impressed with the size and beefyness of the Trail Gear Crawler joints, There not that bad in cost also.
I built lowers for my rear out of 1.5 dom .250 wall with heims on both ends, Won't do that again. The heims when used on both ends tend to lay on there side and bind or loosen up, not to mention the clanking.
I am building new ones out of 1.75 dom with 3/8 wall and taping the tube for a 1.25 shanked Crawler joint on one end and a Ballistic Joint welded soild to the tube on the other end. All my lowers will be this way. I aiming for 34 - 36 inch lowers.
Here is a mock up picture with a short piece of DOM, Just to show what I am doing
-[B]Mike[/B]
[/URL]
Old 06-20-2009, 01:22 PM   #18 (permalink)
Member # 115187
The tank already over hangs the gate.
-[B]Mike[/B]
[/URL]
Old 06-20-2009, 01:25 PM   #19 (permalink)
Spy
TayJ's Avatar
Member # 106637
And thats why I need to build the box out of heavy steel to protect it. Tie the box into the frame. And stretch the wheel base to help departure angle. It will always over hang.
90 shadow 1100cc dd
Old 06-20-2009, 01:46 PM   #20 (permalink)
Member # 115187
Sounds like you don't need any help, Good luck.
-[B]Mike[/B]
[/URL]
Old 06-20-2009, 01:49 PM   #21 (permalink)
Spy
TayJ's Avatar
Member # 106637
Wrong! I need all the help I can get. First time doing a crawler project and I don't know whats best, thats why Im here.
90 shadow 1100cc dd
Old 06-20-2009, 02:12 PM   #22 (permalink)
Member # 115187
Ok,
Like I said earlier
I would use no smaller than 1.75 DOM .250 walled on the lowers and the uppers can be smaller DOM they won't see the abuse.
I would not butt weld them
Get some DOM, Tube Inserts and go to town. If you want to save money, make only one end adjustable.
Check out Ruffstuff they sale, trusses and brackets, thats where I get my stuff, They sale it cheaper than I can make it.
-[B]Mike[/B]
[/URL]
Old 06-20-2009, 02:14 PM   #23 (permalink)
Spy
TayJ's Avatar
Member # 106637
My jeep runs, drives and stops. It crawls 4.0 trails. It looks and preforms like shit. Im a broke ass guy supporting a family. I just have big dreams of having a good trail rig. I plan on getting a small credit card to buy metal and shit, I am looking for advise on what to buy. Wife can't know about my credit card plans either! I have a hyd tube bender, welder, notcher and some air tools and the skill to fab the stuff up.
90 shadow 1100cc dd
Old 06-20-2009, 02:15 PM   #24 (permalink)
Spy
TayJ's Avatar
Member # 106637
Ok,
Like I said earlier
Thanks
90 shadow 1100cc dd
Old 06-20-2009, 02:19 PM   #25 (permalink)
Member # 115187
Join the crowd
-[B]Mike[/B]
[/URL]
