1990 wrangler daily driver ?s - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-27-2009, 10:06 PM   #1 (permalink)
Member # 129876
Question 1990 wrangler daily driver ?s
I have a 1990 jeep wrangler that i wanna do a spring over axle on but i was told that it'd be hard to keep it on the road if i did that the handlin would be bad is this true?
cody1 is offline   Reply With Quote
Old 06-27-2009, 10:14 PM   #2 (permalink)
Member # 59753
All depends if your almost an expert at getting the front set up properly.
80% are not that is why theirs rides like shit. It seems a cheap way to go but it will cost you more than a quality lift kit in the end.
[QUOTE=ChevyGal;9752200]I personally think it's cool Janet Reno likes to wheel. :)[/QUOTE]
Alfred W. is offline   Reply With Quote
Old 06-27-2009, 10:30 PM   #3 (permalink)
JonsYJjeep's Avatar
Member # 47464
I never went SOA. I always kept my rig SUA with 4" Skyjacker leafs. 1" body lift, and a belly up skid. I ran 36" Irok's for the longest time. i just recently went up to 39.5"s TSL's, but I am linked up front now and still SUA in the rear.
When I was SUA all around it handled fine on the road. I even took the sway bar out and track bars front and rear.
My 7/8 ton YJ build
JonsYJjeep is offline   Reply With Quote
Old 06-27-2009, 10:34 PM   #4 (permalink)
timritchieblue's Avatar
Member # 120912
just coin up for the proper sterring, about $700 should do it
2000 tj with some stuff
2001 C5 COUPE
timritchieblue is offline   Reply With Quote
Old 06-28-2009, 12:33 AM   #5 (permalink)
Banned
Member # 64372
i have a 88 wrangler soa stock stearing drives fine down the road rides good too
greenjacob is offline   Reply With Quote
Old 06-28-2009, 05:13 AM   #6 (permalink)
xPOLYMATHx
LucasFury's Avatar
Member # 113176
Send a message via AIM to LucasFury
^Don't listen to this guy^
Steering issues need to be addressed when running SOA.
Why do you want SOA?
Dirty deed done dirt cheap!
and custom leather belts and such too.
1979 FSJ Chief almost for sale. Inquire within.
LucasFury is offline   Reply With Quote
Old 06-28-2009, 06:34 AM   #7 (permalink)
Member # 40587
My last YJ was SOA, all done right, I have the pics to prove it. D44s, BTF hi-steer arms, 1-ton steering, all proper geometry. And while it would do highway speeds on its own if I ever had to make an evasive manuever It would probably veer out of control quite quickly. The suspensions if done right are just too soft, same thing with 4-linked coil rigs. I had a deer jump out infront of me one day and I had to slam on the brakes (upgraded discs and MC btw so it could lock up my 37s) and naturally having such a soft suspension the front end dove and was all over the place almost to the point where I had to fight to keep it inbetween the lines.
You don't want SOA for a daily driven rig. They can drive fine on the street, they get a little scary when the SHTF, and SOA isn't cheap to do right. Plus if you are running a 35" or smaller tire then theres no reason to be going SOA in the first place. Ive even seen guys on here running 37 and 40" MTRs with only 2" of lift.
[QUOTE=Dieselmh]I'll cave his fucking head in with a shovel, just to show him that just because he has opposable thumbs, that doesn't put him on the same badassedness level as humans. Stupid arrogant possums. :shaking:[/QUOTE]
The Black Sheep is offline   Reply With Quote
